Need Help guys, Squeaking noise from front wheel
Has anyone had this problem from their max. When ever i'm driving my max I get this sqeaking noise coming from the wheel. It's much louder when I go over bumps.
Bad strut mounts will squeak driving normal, ESPECIALLY over bumps. If it only squeaks while making turns its the strut bearings. Blown struts on their own could make a squeaking noise, but from personal experience, my car has stock blown struts and they dont make a sound (my mom's Taurus' struts are a different story, those are blown as well and they do squeak alot).
I'd had two things cause squeaking like this:
1) the spring insulators that cover the spring at the top and bottom - using that coil-type wire loom makes for a good replacement
2) worn rubber bushing on the sway bar - the one under the steering rack.
Dave
Dave
if your on a stock suspension, and you only hear a squeak when you go over bumbs, more than likely i would suggest its a control arm bushing.. you can try to push the front of your car up and down to see if you can make it squeak to get a better idea of where its comin from.. you can even just bring your car to a mechanic and let them have a look at it.
Originally Posted by kmb38
I have the same problem and a mechanic told me i had bad shocks and that I needed new ones.
The spring insulators sometimes squeak, and you can't get new spring insulators from Nissan separate from the entire spring. IMO that's a waste of money - it's not hard to use other materials to replace the insulator and reuse your springs. If the mechanic was talking about Nissan parts, and by shocks you meant to say springs, this could be a legitimate answer.
Dave
Hondarydr
Dec 30, 2024 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
BassAddictJ
Aug 4, 2015 11:38 AM
