Replacing rotors, cheaper ones cause squeeking??????
Old Mar 23, 2005 | 06:56 PM
Maxima 504's Avatar
This weekend I will be replacing all rotors and pads.. I am getting good brake pads that I know for a fact do not dust much or squeek.. But my question is that if I get the fairly cheaper rotors would that cause any squeeking later on??
I mean the rotor just sit there and are metal, and cannot be much difference from any of them, or am I mistaking?
All help is greatly appreciated.. Thanks
Old Mar 23, 2005 | 08:37 PM
4GenMaxMan's Avatar
Cheap rotors wont cause noise but they are more prone to warping. Make sure you get good ceramic or equivalent pads.
Old Mar 23, 2005 | 09:08 PM
NmexMAX's Avatar
dot dot dot ...
Thermal properties, casting methods, phase the metal is in when taken out of the cast, but all these essential paly a small role here, unless the synthesis of the rotor is greatly differed from other methods of process, but in this case, all negligible.
Old Mar 23, 2005 | 09:19 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
I recommend you get these.
http://www.buybrakes.com/store/HB268-665 Pads For front
http://www.buybrakes.com/store/HB421-622 Pads For Rear
And these Rotors:
http://redlinemax.com/catalog/produc...1c2ce84c90fb14
For Front
For Rear
Old Mar 24, 2005 | 03:56 AM
dgeesaman's Avatar
Maintenance Monster
Boy that reads worse than ****ens.
Rotors are basically just heat absorbers - good ones will be made of a material that won't warp or wear too quickly, especially when pushed to their thermal limits. Buy good quality basic rotors and don't worry about them, if you ask me.
Squeaking is typically caused by pad vibration (or the wear indicator on the old pads). When installing new pads, I strongly recommend buying a shim (brake hardware) kit, and liberally cleaning the caliper assembly with brake parts cleaner. The shims control pad vibration better than any anti-squeal pad goop can.
Dave
Old Mar 24, 2005 | 05:00 AM
tofor's Avatar
Squeaking? Likely more a pad thing than a rotor thing. To truly avoid squeaking, don't use the cheapo semi-metallic pads. As far as the rotors go, just make sure you don't buy the Chinese knock-offs for like $20/ea at PepBoys/Autozone/etal. Stick with US/Canadian aftermarket, OEM, or performance parts.
The links provided above, btw, are excellent choices.
Old Mar 24, 2005 | 06:37 AM
Conrad283's Avatar
I need a truck
My mechanic told me that the squeeking is caused my vibration. Just make sure they do a good job.
Old Mar 24, 2005 | 11:42 AM
Maxima 504's Avatar
Thanks for all you guys input and help. I may have to get some of the Brembo rotors that CystumMax recommended. Redlinemax.com says its $89.00 for front and rear, so i'm leaning towards them. I will also be replacing the brake hardware being that my car is like 10 yrs old and on the stock hardware probably.
Can anyone else recommend these rotors or can compare them to the reliability from warping and such to the stock rotors??? Thanks.
Old Mar 24, 2005 | 11:43 AM
gtr_rider's Avatar
192.168.1.1
Try some of these, http://www.vqpower.com/v2/article136.html
Old Mar 24, 2005 | 11:58 AM
Maxima 504's Avatar
haha yeah, I wish I could get some cross drilled/slotted Brembo's. Looks great with your 2k1 AE rims. I'm on a budget thoguh so i'm most likely gonna get the basic Brembo's..
Old Mar 24, 2005 | 12:00 PM
Maxima 504's Avatar
BTW thanks gtr_rider for the website.. It will definitely help on the installation since this will be my 1st time doing the brakes on my max myself..
Old Mar 24, 2005 | 12:30 PM
dgeesaman's Avatar
Maintenance Monster
Brembo blanks are good rotors, and not very expensive. I strongly recommend them.
Dave
Old Mar 24, 2005 | 12:44 PM
CystumMax's Avatar
Originally Posted by gtr_rider
I want to let you know, Brembo does not make Cross Drilled/ Slotted Rotors. Those rotors you see in that picture are the blank Brembo Rotors, They where made into cross Drilled/ Slotted Rotors. These are the Real Brembo one's and they don't come in silver color.
http://www.buybrakes.com/brembo/sport-rotors.html check it out.
Old Mar 24, 2005 | 01:26 PM
newdiamond's Avatar
Duhhhh...all sound is caused by vibration
Old Mar 24, 2005 | 02:54 PM
Maxima 504's Avatar
one more question about these Brembo rotors from redlinemax.com... What kind of coating is there on them.. . Zinc coated??? I really dont know much about this subject.. thanks..
Old Mar 24, 2005 | 03:05 PM
maxima_kenny96's Avatar
I dont think you should be so much conserned on Rotors squeaking, but more so if they are going to crack or brake later down the road.
Old Mar 24, 2005 | 04:28 PM
dgeesaman's Avatar
Maintenance Monster
Coating is worthless, it rubs off pretty quickly. A rotor is designed to be plain steel (unless it's a porsche or F1), so a little rust is normal if the car has been sitting.
Dave
Old Mar 24, 2005 | 05:06 PM
gtr_rider's Avatar
192.168.1.1
If you read the whole page, you wouldnt have posted this but ok.. I knew that
Old Mar 24, 2005 | 07:31 PM
CystumMax's Avatar
oh yeah, My bad, I messed up.
Old Mar 24, 2005 | 08:45 PM
konak85's Avatar
I just did my brakes on all four, pads and rotors. I put cheap rotors on. Its been two weeks and theres some stuff that looks like rust on them already. Tried rubbing it off a bit with a rag, didn't come off. Whats the best way to get that stuff off? Is it cause of cheap rotors or something else?
Old Mar 27, 2005 | 06:02 PM
Maxima 504's Avatar
Hi, I was about to order the rotors right now but noticed on the pic that they had like 12 or so holes for the lugs.. I was wondering if they are universal rotors or something because my stock only have holes for like 5 lugs.. Anyone have any idea why??
Old Mar 27, 2005 | 06:41 PM
Maxima 504's Avatar
Oh well i just ordered them anyway. Thanks for all the help in this post..
Matt93SE
May 24, 2019 02:58 PM
MattWithTheMaxima
Jun 30, 2017 01:06 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
