Check Engine / Right Blinker
Old May 6, 2001 | 08:31 PM
TepsMaxima
I have a 1995 Maxima SE with 63,000 miles on it and the check engine light recently came on. I believe at the same time the right, front blinker has stopped working. My first thought was a burnt bulb and I changed it-- no change. Also, the car is totally stock. I've heard horror stories about taking the car to a dealer and spending hundreds of dollars with no avail. Are these two incidents related?
Thanks.
Old May 6, 2001 | 08:48 PM
Sprint's Avatar
only one way to find out
http://vbxmaxima.8m.com/ecu.html
pull the code and let us know
we will tell you
Thanks.
Old May 7, 2001 | 04:16 AM
Daniel B. Martin's Avatar
Thanks.
The two symptoms are probably unrelated. If the bulb is good, examine the bulb socket and the wiring leading to it.
The Check Engine Light is evidence that something is wrong. That
"something" may be any number of things, some major and some minor. It
might be nothing more than a loose fuel filler cap. The Engine Control
Module (the computer) detected a problem and turned on the Check Engine
Light. At the same time it stored one or more Diagnostic Trouble Codes.
Get someone to do a DTC readout for you. This is not a big deal, does not
require specialized "dealer only" test equipment, and should take less than
an hour. When you know the stored DTCs, you will have a fair idea of what
repairs are needed.
If you like to do your own "wrenching" you can do the DTC readout for
yourself. No special tools are required.
You will find instructions to do a DTC readout and reset
the Check Engine light at:
The DTC "translations" are found at:
http://vbxmaxima.8m.com/ecudecoder.html
Old May 7, 2001 | 04:27 PM
TepsMaxima
Thanks Daniel...I'll check out the web sites
Thanks Daniel, I'll check them out. And, I'll check the light socket.
QUOTE]Originally posted by Daniel B. Martin
repairs are needed.
[/QUOTE]
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
cruce91
Sep 20, 2015 10:23 AM
mikebla
Sep 3, 2015 05:37 PM
A32goldylocks
Sep 2, 2015 06:39 AM
