manual trans upgrades?
Old Mar 24, 2005 | 03:36 PM
RI-Max's Avatar
ok im looking 2 upgrade my trans. cause i keep on blowing junk yard ones. what upgrades at thes getting a locking diff? freezing the gears??? plus i was wondering how hard i'll be if i do the work. neva took apart a manual trans. (just the cover) ive done auto trans rebuilt. but ive heard manual are easier. and got any ifo. plus whats the betta locking diff? quife?(can't spell)
Old Mar 24, 2005 | 03:40 PM
Ant96GLE's Avatar
Unless your boosted.. how the heck do you keep blowing them???
Stop redlining at every red light
If you keep blowing them for whatever reason, unless the junk yard ones are crap, they are going to keep blowing. Get a 2k or 2k1, they are supposed to be stronger.
Good luck trying to find a Quiafe.. its no longer being imported.
Old Mar 24, 2005 | 04:19 PM
RI-Max's Avatar
i just drive hard . anyone know hwere i can get a input shaft and main 2nd gear cheap??? or trans partrs?
Old Mar 24, 2005 | 04:27 PM
dgeesaman's Avatar
Maintenance Monster
Me suspects you can't shift correctly. Driving hard is different.
Old Mar 24, 2005 | 04:31 PM
RI-Max's Avatar
can't shift correctly no can't spell yes. but this thread is not about my driving ***********. so shut up.
Old Mar 24, 2005 | 04:34 PM
Ant96GLE's Avatar
Nah, but I would highly consider the 5th gen trans... other than that for 5 speeds the only other thing you can really do is crryo treat the gears. Which is $$$
Old Mar 24, 2005 | 04:58 PM
vortechpower's Avatar
.................... cryo treating is $300 for the whole trans
Old Mar 24, 2005 | 05:38 PM
larryseibel's Avatar
if you got the know-how and tools to rebuild an auto then you should be able to do a 5-spd easy! what is freezing the gears? i hope your not talking about tig welding the diff gears to get the axles to lock? that would be a mistake unless you plan on only driving straight. cryo is a good idea
Old Mar 24, 2005 | 05:56 PM
maximabebe's Avatar
Are you seriously 20 years old? I can't understand what you are trying to say. Anyways, I agree with Ant on this one....get yourself a 2K1 tranny.
Old Mar 25, 2005 | 03:07 PM
RI-Max's Avatar
yes i am 20 is their a problem? ok i will looking into a 5 gear trans thanx. btw i meat crryo treat.
Old Mar 25, 2005 | 07:28 PM
MrEous's Avatar
^ Jeff™
Actually the trouble you are experiencing is most likely due to your driving. Too many people on here w/out forced induction are running just fine on stock trannys...
...unless you're just getting bad trannys. How many have you gone through?
Old Mar 25, 2005 | 07:34 PM
yeah...you must be gettin' some junk trannies because i beat the heck out of mine and its the original 5spd w/almost 170,000. i take it to the track for bracket races at least 5 times a year and slam gears all the time when i screw around on the street. how many have you gone through? maybe you got some other issue that is causing them to go like axle wobble or misaligned drivetrain. idunno but i didnt think our trannies where THAT bad.
Old Mar 25, 2005 | 08:24 PM
maximazation's Avatar
will the 5th gen tranny bolt right up to the 4th gen?
Old Mar 25, 2005 | 08:29 PM
change the axles to the new style. there are a million threads about this.
Old Mar 25, 2005 | 08:30 PM
i know, this was on-topic so i thought it wouldn't hurt to ask
Old Mar 26, 2005 | 11:11 AM
RI-Max's Avatar
oo i didn't know u have 2 change the axles. for a 5 gens trans.... but like i said i don't drive normal i drive like a **** head. im burn out king . but like i said this threads about builting up a trans.
gone thew 2 trans in 3 years lucky i work on car for a living so i can do every thing my self
Old Mar 26, 2005 | 11:16 AM
CaLSoNiC
stop driving like an asshat and your trannies will last.
Old Mar 26, 2005 | 11:20 AM
RI-Max's Avatar
ok mommy
SHUT UP b i t c h a s s
Old Mar 26, 2005 | 03:32 PM
dgeesaman's Avatar
Maintenance Monster
ok mommy
Doing burnouts in a 4D FWD car = Burnout queen maybe.
Seriously, the nut behind the wheel needs replaced. You're not gonna find much to upgrade this tranny because it's a 4th gen Maxima, not a Mustang. You want to slam gears and forget to pop the clutch, buy a Camaro.
Dave
PS Don't forget to put in the drain plug. Wouldn't wanna get fired from Jiffy Lube.
Old Mar 26, 2005 | 05:52 PM
RI-Max's Avatar
Dave
i guess im come down 2 RI and say that. i slap u like the b i t c h u are tuff guy.
Old Mar 26, 2005 | 06:25 PM
MrEous's Avatar
^ Jeff™
Don't let insults bother you...most of the time the people that are insulting you do it for fun. Other times it isn't worth e-fighting with an e-thug.
Get into a pissing match will only get your threads closed...whether or not they are helpful.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
