Speedo Problem
Old Mar 25, 2005 | 10:48 AM
ibrahimekawi's Avatar
Speedo Problem
My speedometer a few days ago started acting up, i was probably driving about 100km/h and my speedo said i was going 60km/h, but i wasn't even steady it was bouncing up and down...and then it just started going to zero, but only on high speeds it will jump to 20km/h and it still bouncing up and down...does any one know what i can do, or what the problem could be?? help please
Ibrahim
Old Mar 25, 2005 | 11:42 AM
mbandi's Avatar
Da'Burgh, Go Stillers!
It often times is the speedometer head going bad. Vehicle speed sensor is also a possibility. I had to replace the speddometer heads on my 3rd gen. and my 4th gen.
Old Mar 25, 2005 | 11:48 AM
MaDMvD's Avatar
I had a similar problem occuring not too long ago, although I got a code 0104 (speed sensor). I replaced the speed sensor, reset the ECU, and the error code came back. Apparently, a lot of people had successful stories of removing their cluster, cleaning/dusting out the parts, and re-tightening everything back into place. I decided to try that, and what do you know? It never happened again. Before changing out anything, that's what I would do. It takes about 5-10 minutes, and it's free. If it doesn't help, change the speed sensor (~$25), if that doesn't do it either, I would then change out the speedometer head and/or entire cluster. You can find instructions on how to remove the gauge cluster here:
http://www.geocities.com/amixam69/ni...ash/index.html
Hope this helps, good luck!
-Maurice
Old Mar 25, 2005 | 11:57 AM
Supermax95's Avatar
Is the odometer working when the speedo stops? if not it could be your speed sensor....if your speed sensor goes out it should give you a code though.
Old Mar 27, 2005 | 07:04 PM
ya both the speedo and the odometer are not working, im gonna try taking it apart and checking if everything is intact, thank for the help guys, ill let u know what happenes
Old Mar 28, 2005 | 10:32 PM
Broaner's Avatar
2060lbs and falling...
Any update on this? My speedo and Odo are not working either. But this is after a 5Spd swap.
Old Mar 29, 2005 | 05:39 PM
Supermax95's Avatar
Check your speed sensor...
Old Mar 29, 2005 | 06:44 PM
Broaner's Avatar
Thanks. I figured it out just after posting this last night. The dummies at the yard sent me a tranny without any speed sensor. I'm going to try to use the auto one.
Old Mar 30, 2005 | 09:42 AM
I hooked up the car to a computer and it showed that the vss sensor is malfunctioning, so does anyone know where it is located? i know it's on the transmision somewhere but exactly where i don't know!!!
Old Mar 30, 2005 | 10:17 AM
Broaner's Avatar
Its on top of the diff. One 10 milli bolt hold it on. Mine has a white heat shrink around the wire harness.
Old Mar 30, 2005 | 10:20 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Ibrahim
That happens to me when I am High.......
Old Mar 30, 2005 | 12:24 PM
it's deffinetly the speed sensor, i found it it was on top of the transmission close to the windshield, i ordered it from the dealership, its about $30. thnx for ur help everybody
Old Mar 30, 2005 | 05:14 PM
Broaner's Avatar
At my dealership it was $22.50.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
