problem with acceleration
Old Mar 28, 2005 | 08:14 AM
Nissan2k5's Avatar
hey guys i dunno what the problem is but since i got my max it just seems like well i try to accelrate theres somethin holding me back or somethin clogged in there. it seems like im tryin to push somethin out like its not runnin as smooth as it should can anyone help me. i have 160k miles on my 95 se 5 speed. any help will be appreciated thanks
Old Mar 28, 2005 | 08:15 AM
NmexMAX's Avatar
dot dot dot ...
Stickys/FAQ's might help you out .. read them ..
Old Mar 28, 2005 | 08:18 AM
MAXRB8's Avatar
Try pulling your codes from the ECU it's in the stickies under How to's. Check to see if you have the infamous 0304 Knock sensor, it doesn't bring up the CEL. Some inexpensive suggestions would be to change the plugs (NGK only!) replace air filter, clean the throttle body and the IAC valve, again also in the stickies! Good luck
Old Mar 28, 2005 | 09:58 AM
Silverbullitt's Avatar
Check for the 0304 knock sensor ecu code. Mine has gone bad and is dead power wise between 2k and about 4k
msellas
Sep 23, 2015 09:16 PM
jchronis2552
Sep 21, 2015 05:52 AM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
