how do i...keep clock illuminated
Old Mar 29, 2005 | 10:41 AM
empathyvoid's Avatar
hey guys,
I know this is in the "how tos" sticky post but the link doesn't work for me, seems like its broken
but i was curious if anyone could let me know how to make it so my digital clock is always bright rather than dimming when i turn on the lights
Thanks.
Old Mar 29, 2005 | 10:47 AM
AllMaxxedOut's Avatar
After you pull the clock out you will notice the wires that are wrapped in the foam. I believe that you have to cut the red wire to keep the clock always illuminated. But just to be safe, let someone confirm that as I don't want to be liable for anything going wrong.
Old Mar 29, 2005 | 10:53 AM
DragonMaxima's Avatar
Found this on VQpower.com-
Warning: This procedure is very dangerous, you can very easily screw up your wiring. The key to doing this is taking your time and looking everything over twice before doing it.
Written by Daniel B Martin
If you want the clock display to remain at high intensity when the lights are on...
1) Remove the clock. This may be done with a small flat-blade screwdriver. Insert the screwdriver blade between the lower right hand corner of the plastic dashboard clock panel and the adjacent softer dash board. Slowly pry the panel up. Continue this at all four corners of the contoured panel until the metal snaps which anchor the panel are loose. Remove the panel by pulling outward and downward.
2) Note that the clock's electrical connector has four wires. Cut the wire which is red with a blue tracer.
3) Install the clock panel. It just snaps into place.
Old Mar 29, 2005 | 11:02 AM
awesome, thanks a lot guys, it worked. appreciate the help
Old Mar 29, 2005 | 12:15 PM
kbmaxima's Avatar
hope your climate control lights didnt go out like mine did =T
Old Mar 29, 2005 | 07:15 PM
HomerMAC's Avatar
Donating i30 Owner
any way to keep the guages lit all the time.. i hate going under an overpass.... and not seeing a stupid guage.
Old Mar 29, 2005 | 07:39 PM
Wetballoon's Avatar
Mount a light that shines on them and leave it on.
Old Mar 29, 2005 | 07:41 PM
Wetballoon's Avatar
Actually, you can probably find the wire that powers the lights, most likely from the dimmer, and kick it over to an ignition circuit so it comes on with the car.
gavin68
Sep 18, 2021 12:36 PM
jc53
Oct 12, 2015 05:12 AM
BobTX10
Oct 7, 2015 08:43 AM
kadespraggins
Sep 14, 2015 12:04 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
