gargle sound comming from the engine...HeLp plz...
Old Mar 30, 2005 | 03:53 PM
ThisMaxIsTight's Avatar
hey guys...sitting in my car I can hear something of a rattle sound in the engine bay, I might add pretty loud, so I lift the hood and check the oil which is fine...when I rev the throttle cable, its like a high pitch gargling, almost sounds nasty like the engine its choking...the sound gets faster as I rev the rpms, then as the rpm's go down, it still gargles but slower and softer-its comming from the intake manifold and throttle body area...its hard to tell EXACTLY where the sound is comming from...not sure if its something inside the engine or outside ... info to be known: 98, auto, just did 90k service, all the main. is done that I can think of-I have an evap code and a 1448 code, is also not the timing chain tensioner....any help from you maxima buffs is greatly appreciated and I thank you in advance for your input
Old Mar 30, 2005 | 07:06 PM
anyonnnnnnnnnne... ?
Old Mar 30, 2005 | 07:15 PM
mrgreek's Avatar
ur guy at the 90k threw a wrench in...i don tknow, im clueless, lol, im just bumping this for u so it stays at the top cause that sux
Old Mar 30, 2005 | 07:31 PM
MDeezy's Avatar
not too knowledgable on the evap sutff but dont think it would cause such a noise, that code poped up after the 90K service?
Old Mar 30, 2005 | 07:33 PM
Nismotic's Avatar
Always sunny in philly
i have the same problem and have yet to figure it out.
Old Mar 30, 2005 | 07:55 PM
mrgreek's Avatar
nismo, ur avatar is a perfect donut, i love it
Old Mar 30, 2005 | 07:57 PM
PAREDLINE's Avatar
sounds like your valve train. Probably nothing you can do short of a valve job.
Old Mar 30, 2005 | 08:16 PM
thanks for the input guys....what exactly do you mean by a valve job?...replace all the valves?....how long/expensive is this?
Old Mar 30, 2005 | 08:20 PM
nick's Avatar
re: clatter noise
This clatter gurgling noise is quite common to high milage 4th Gens, it is caused by EGR Back Pressure Transducer Valve which is located right next to EGR valve ( it is a royal PITA to replace btw )
let me guess - the noise goes away once the engine is warmed up - right?
and it is mostly noticable in cold weather?
I've had this noise for past 45k and i just learned to live with it , my ECU never threw any codes associated with EGR system ,
so if it aint broke , don't mess with it !!!!
Nick.
PAREDLINE's Avatar
The only moving engine parts around your intake manifold are the camshafts and valves. It might just be a vacuum leak. Its not something that can really be diagnosed online.
I know the altimas have a plastic timing chain guide that melts and causes a gurgling noise. but on the other side of the engine.
Old Mar 30, 2005 | 08:24 PM
nick's Avatar
the membrane of EGR BPTV gets old and gurgles !!!! an it is a moving part along with EGR valve and handfull of other moving parts around IM.
Nick.
Old Mar 30, 2005 | 08:59 PM
nick and PAREDLINE thank you so much for your informative input...this is definitely gonna be tough to diagnose...im gonna look into both ideas as for what the sound is.... another thing-there is no power loss
Old Mar 30, 2005 | 09:13 PM
nick and nismotic...how is your gas mileage?, mine dosent seem to good at all...mine might be 18-19 mpg
Old Mar 30, 2005 | 10:05 PM
nick's Avatar
that sounds about right in winter time , I get about 19-21 mpg of combined city/highway driving.
Nick.
JRod28
Dec 29, 2023 09:56 PM
seesole
Aug 26, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Abdelrhman
Aug 17, 2015 12:16 PM
AT978
Aug 15, 2015 06:39 PM
