All who run with 18's
Old Apr 3, 2005 | 05:06 PM
  #41
A Flood99's Avatar
sky 99, you have zenetti fives, you go with the silver or chrome? man, when i was looking for wheels i was almost set on buying them....they are a very clean looking wheel.....you have any pics?
Old Apr 3, 2005 | 05:37 PM
  #42
Doc's Avatar
Doc
Zenetti 5's and Miglia's, wow. You guys spent some real dough on your 18's. Very nice look both of them, for sure.
Old Apr 3, 2005 | 08:10 PM
  #43
Doc's Avatar
Doc
Originally Posted by A Flood99
if you're sticking with the stock springs you'll be fine, but of course watch out for potholes.....but i even did that w/ the 16"s
i run 245/40/18 tires and will never go back to stock as long as i own my max
Flood, you mean 245's fit fine with no rubbing issues? Looks like you're lowered some, too.
Old Apr 3, 2005 | 09:19 PM
  #44
VIP Maxima
Originally Posted by lex4style
I've had them for about a yr. And they have treated me well. I been to two trips to NY on them and they are in perfect condition. My next set will be 19's EV-S Mille Miglia.
my baby is gonna wear those very very soon. 18's are so 2002ish, its time for dubs -1
Old Apr 4, 2005 | 04:19 AM
  #45
Sky_99's Avatar
I went with the silver, I'm not a big fan of chrome. I didn't take any pics last year, but I should be putting them back on this weekend and I will definately take a few pics.
Old Apr 4, 2005 | 05:31 AM
  #46
Minimalmaxima's Avatar
Hey Flood you got any exhaust mods on your car? I'm thinking of buying a Cattman Y-pipe and I need to know a good place around ATL to get it installed. I mean a good place but not a ripoff. There's a bunch I see but I don't have any clue about reputation or price or anything. BTW, anyone ever thought about putting 350z 18's on, or even doing it? I think I'm going to do that. I've figured it up and looks like they should fit.
Old Apr 4, 2005 | 05:57 AM
  #47
venommaxr33's Avatar
I'm running 19's with 235/35/19 Nitto 555 Extreame's, lowered suspension and KYB AGX adjustables and my handling is great. the ride is a little rough but i guess it comes with the territory. im about to switch over to the tokico HP's and see how those work out. for braking I upgraded to X-drilled and slotted all the way around so there's no problem there!
Old Apr 4, 2005 | 07:24 AM
  #48
Doc's Avatar
Doc
Venom, sounds like you have a really nice set up there and about to get even nicer. Do you have any pix to post?
Old Apr 4, 2005 | 09:38 AM
  #49
MAXRB8's Avatar
I have 245's as well no rubbing issues at all same as Flood, we both have Alessio's not Mille Miglia's, I couldn't be happier with the ride, I previously had 17" but it was a look thing for me. But when you drop make sure you go with an adjustable shock ( I run illumina's excellent with eibach's) , you can adjust your stiffness then the difference between 17" and 18" is irrelevant. Consider 245's
Old Apr 4, 2005 | 10:28 AM
  #50
jblinga's Avatar
I've been running 18x8 Voxx Scorze w/235/40s for 20,000 miles now & I'm very pleased w/the change. Performance change from my stock 15s was night-day. Stock brakes didn't seem to have probs but I only ran the stock brakes for 15,000, now I have the 300ZX BBK. My next set of tires I'm going to 245/40s, but I'm still waiting for Discount to get these in(1 week been waiting) I swapped out the stock springs about 10,000K ago to Eibach pro kit. Alot rougher ride but w/KYB AGXs handling was once again improved night-day. Hope my feedback helps!! jblinga
Old Apr 4, 2005 | 12:16 PM
  #51
A Flood99's Avatar
the 245 size tire looks very nice on an 18" rim, it also adds protection against curb rash
Old Apr 4, 2005 | 12:22 PM
  #52
Doc's Avatar
Doc
It does help a lot. Thanks, J.
Old Apr 4, 2005 | 12:23 PM
  #53
Doc's Avatar
Doc
Flood, do the 245's stick out of the wheel well at all? If so, I don't want this.
Old Apr 4, 2005 | 12:28 PM
  #54
Sky_99's Avatar
That would depend more on the rim offset than the tire's width.
A 245 series is only 0.39" wider than a 235.
Old Apr 4, 2005 | 12:34 PM
  #55
A Flood99's Avatar
no, no sticking out.....it just looks like the rim has more rubber surrounding it
hard to explain, but when i get new tires i'll try and run a 255......you would definitely see the difference if you compared a 225 and 245 tire side by side.....the 225 makes the wheels look cheap
also, sky 99 good choice on silver for the zenetti's
Old Apr 4, 2005 | 12:35 PM
  #56
Doc's Avatar
Doc
The offset on my rims are 38mm...what do you think?
Old Apr 4, 2005 | 12:36 PM
  #57
A Flood99's Avatar
here's a pretty good pic of my 245/40/18 tires:
with a 38mm offset, you'd be fine running a 245 and it would look damn good
Old Apr 4, 2005 | 12:42 PM
  #58
Doc's Avatar
Doc
They fill up the well nicely without overflow. Keep the pix coming, brother. Looks nice. I guess it's good we drive 4x4's, a lot of room for big rubber. How heavy are your Miglias?
Old Apr 4, 2005 | 12:47 PM
  #59
A Flood99's Avatar
they are made by alessio actually, and have a few slight differences from the evo5's, like the lugs being placed between the spokes
weight wise, i need to actually put them on a scale the next time i take them off.....i do know they are slighty heavier than stock since i swap them back and forth a lot....mainly just when the car goes on long trips or when i had some body work done a few months ago
Old Apr 4, 2005 | 12:57 PM
  #60
Doc's Avatar
Doc
I see. They are nice looking wheels. I found out my Muranos weigh 35lbs. My stockers are only about 20lbs. Pretty good weight difference.
Old Apr 4, 2005 | 01:04 PM
  #61
A Flood99's Avatar
yeah mine are probably in the 28-30lb. range
just remember the tires you're going to put on there will weigh less than the stock ones, so you'll gain a little ground there
just weigh each tire/wheel combo when you get your new tires mounted and see what the actual difference is
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
