Idle problems
Old Apr 1, 2005 | 05:27 PM
QuickFast's Avatar
Idle problems
When I first turn on my Max in the morning, the idle always climbs up to 1300 for like 15 mins., then it slowly drops down to 700 where its supposed to be. Can anyone explain this problem I am having?
Old Apr 1, 2005 | 06:06 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
your car is in open loop. you need to warm up your car. start the car, and then drive, dont wait 15 mins. wait 30 secs max. if you wait 15 mins your cylinder bores and pistons are wearing out faster than normal. peak operating temperature is about 210 degrees, not ambient temps.
Old Apr 1, 2005 | 06:23 PM
QuickFast's Avatar
Thanks, but do you know why it starts out at 1300 rpm? Shouldnt it always be 700 rpm at idle?
Old Apr 1, 2005 | 06:26 PM
killcrap's Avatar
idk, ask your ecu and tps sensors. this is normal for all cars. if you had 700rpms at start up, your car would stall. you need a rich fuel mixture on start up.
Old Apr 2, 2005 | 05:37 AM
QuickFast's Avatar
Ok, thanks for the info.
Old Apr 2, 2005 | 06:16 AM
deeloc's Avatar
its completly normal. i'm sure on very cold days at first startup the idle may be even higher at first, like 1500 rpm's and then slowly work its way down as the engine warms up
Old Apr 3, 2005 | 02:57 PM
el_muchacho_qc's Avatar
It's very simple. When u start ur car, the engine temp is low. So instead of using the standard iac valve, ur ecm goes to the fast idle control, making ur car idling rev to about 1300, to warm up ur car faster. When it reaches normal operating temperature, goes back to iac, who is normaly set up to about 700 rpm.
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
