Oil leak, dont know where its coming from.
Old Apr 1, 2005 | 05:40 PM
greenmax95se's Avatar
Changed my morot back last year. And this newer 15k motor has a oil leak from somewhere. I dont know where its coming from. check the oil pan, and thats surely not it. its wet higher then that. anyoine habe any idea? its coming from the right and right rear'ish of the motor. its wet around and above the oil filter too. was like that when i brought motor. i lose about 1 quart in 2500 miles driving.
and ideas advice etc? thanks.
-rafal
Old Apr 1, 2005 | 07:50 PM
bump/......
Old Apr 1, 2005 | 08:05 PM
Loe max's Avatar
Could you take a picture of what your talking about?
Old Apr 1, 2005 | 08:35 PM
Broaner's Avatar
2060lbs and falling...
Chalk up another one for the "Rear Valve Covers". Ant will be in here shortly to back me up.
Old Apr 1, 2005 | 08:36 PM
Loe max's Avatar
I take it that its a common problem If so, thats something I'm going to have to look for on my next oil change.
Old Apr 1, 2005 | 09:02 PM
Broaner's Avatar
Yes, its very common but most people think its the oil pressure sensor since its in close proximity to the typical dripdown area from a rear VC leak. Pop off the rear VC and toss some RTV on there. It'll cost you $6 if you do it yourself. If you have someone do it you'll be out atleast $250 because of labor hours(Removing the IM is required.)
Old Apr 2, 2005 | 06:03 AM
the rear valve cover can leak that much oil in 2500k miles? sounds about right i'd say. and i'll definetly have to check that out. cause the whole right and right rear of the motor under teh car is oil wet. leaks from way above the motor. thanks
-rafal
rtirbany
Sep 8, 2015 11:46 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
