How To Check If You Have Limited Slip.
Old Apr 2, 2005 | 02:07 PM
PAREDLINE's Avatar
Ok boys and girls.
Here's how you can check if your differential is limited slip or regular.
1. jack up both front wheels. You can jack up under the cross member if you have a floor jack, or use two separate jacks under jacking points on both sides.
2. While looking at the opposide side wheel, spin one wheel by hand:
If both wheels spin the SAME direction- You have Limited Slip Differential
If both wheels spin in OPPOSITE directions- You do not have Limited slip.
I did this with the car in park and again in gear and it was the same result.
Source: Believe it or not, Pep Boys; and it was confirmed by the local Nissan Dealer Service Dept as the way to know.
Old Apr 2, 2005 | 02:09 PM
Vaudeville Villain's Avatar
This only applies to I30's, correct? I thought no 4th gens came with factory LSD.
Old Apr 2, 2005 | 02:11 PM
PAREDLINE's Avatar
No sir. Applies to both cars. Some maximas did come with LSD. You may have limited slip and not even know it.
Old Apr 2, 2005 | 02:20 PM
DuMKuH's Avatar
Sorry for the dumb question , but just to make sure I understand right what the LSD is, Can you guys explain to me what it is? Thanks
Old Apr 2, 2005 | 02:22 PM
PAREDLINE's Avatar
Its a Limited Slip Differential. When one wheel slips it will automatically reduce power to that wheel and give more torque to the opposite side wheel via something called a viscous coupling.
Old Apr 2, 2005 | 02:32 PM
DuMKuH's Avatar
thanks again!!
Old Apr 2, 2005 | 09:47 PM
sagamax's Avatar
Give me a Bud Light Holmes
check your vin number i beleive that there is a V at the end of the tranny code. correct me if im wrong somebody???
Old Apr 2, 2005 | 09:55 PM
mzmtg's Avatar
Minister of Silly Walks
Old Apr 2, 2005 | 11:54 PM
Zack342's Avatar
Originally Posted by mzmtg
why don't you lock it then this was discussed in a thread a couple days ago.
Old Apr 3, 2005 | 08:28 AM
99SEL4ME's Avatar
Yes, you are right. Seems to me that looking at the vin number would 100 times quicker than jacking up your car.......
Miket2006
Mar 1, 2021 03:55 AM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
Djsmaxima
Sep 14, 2015 11:58 PM
crazyespn
Sep 3, 2015 01:30 PM
