Help
Old Apr 4, 2005 | 05:02 PM
CleanMAX98's Avatar
Help
today while driving The brake light came on, and the battery light, so i went to my dealorship and they checked the battery its putting out 14.5 which is normal, and the brake light stays on even when the e-brake is down
any help is appreciated
thanks
Old Apr 4, 2005 | 05:40 PM
Loe max's Avatar
Did you get your alternator tested also? On mine, those lights signaled a slowly failing Alternator.
Old Apr 4, 2005 | 05:42 PM
MDeezy's Avatar
Test Alternator and check brake fluid level and make sure its not low or close to empty.
Old Apr 4, 2005 | 06:32 PM
jblinga's Avatar
What he said.
Old Apr 4, 2005 | 06:35 PM
sunysb83's Avatar
yup check alternator, also check your belts, same thing happened to me and it turned out to be a tear in one of the belts and it came loose.
Old Apr 4, 2005 | 06:41 PM
CleanMAX98's Avatar
i just got an alt a month ago, they filled the fluids at the dealorship
i will check belts tomorrow, thanks for all your help guys
will also get alt checked, but i just got it checked by nissan two weeks ago because the recall required the install to be checked for my alt to work fine!!! it read ok and in working order, how long is the warrenty on alts? long that <2 months?
Old Apr 7, 2008 | 09:15 AM
gokwi's Avatar
help, i have the same problem as well!! those lights keep going on
i check ym battery, it is good, and i checked my boltage when the car is running, and it has like 14.25 volts...
people said it was the alternator, but why am i getting good voltage?
Old Apr 7, 2008 | 12:10 PM
Snypa's Avatar
thanks
are you trying to say that the dealership didnt/couldnt fix it.?
You did go to the dealership right.?
Old Apr 8, 2008 | 07:34 AM
gokwi's Avatar
bump
Old Apr 8, 2008 | 07:39 AM
udienow's Avatar
gowki, it means ur alternator may be on its way out. You should get it tested see how it checks out.
Old Apr 8, 2008 | 01:37 PM
Snypa's Avatar
i think gowki's car is fine. its someone else that has problems.
Old Apr 8, 2008 | 02:21 PM
gokwi's Avatar
thing is, the voltage on the battery when the car is off is 12 volts, and when the car is on it's 14 volts, so why are my lights still on?
Old Apr 8, 2008 | 06:27 PM
NmexMAX's Avatar
dot dot dot ...
Being that he was asking this question 3 years ago, I'm sure the problem has been resolved.
You say lights, meaning alt / brake?
I'd say it's your brake fluid for the brake light. And if the battery is good, that doesn't mean the alternator is good. Check the alternator @ AutoZone.
Also, what you needed to do is post this question in here: http://forums.maxima.org/showthread.php?p=6343734
Old Apr 8, 2008 | 10:56 PM
gokwi's Avatar
well, i got the problem solved
it was my alternator of course. i guess the voltage regulator went out, and was charging my car up to 18volts!!
