Deep ****, car dead---Need help ASAP
Old Apr 4, 2005 | 05:07 PM
Kevlo911's Avatar
Kevlo for President
My car died as I pulled into my parking lot. I had a piggyback style ECU which was not in. When the car is in ACC position, the check engine light doesn't come on as it should. I tested the pin 72 and it is only getting like 3-4 volts. I don't know why.
Some one tell me what to do. How do I test the ECU to make sure nothing is wrong.
I already elimited gas and battery.
Old Apr 4, 2005 | 05:43 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
I was going to say try to connect a ODBII reader to it and see if you get anything. To see if the ECU communicate with ODBII Reader. The other way of testing it, is to have another ECU from another 97. I don't know any other way.
Old Apr 4, 2005 | 06:17 PM
Kevlo911's Avatar
Kevlo for President
ECU pins 67 and 72 are the ones that power ECU. They are not getting 12v, so it won't be able to read from OBDII port.
Old Apr 4, 2005 | 06:20 PM
cassiejeffie's Avatar
Check your ECM relay, sometimes resistance in relay lowers the voltage causing the car to not run.
Old Apr 4, 2005 | 06:45 PM
Kevlo911's Avatar
Kevlo for President
Fixed it, thanks to my friend Joe.
ECCS fuse blew
Old Apr 4, 2005 | 07:59 PM
killerVQ30DE's Avatar
Nice work fixin it, sounded like a stumper
Old Apr 4, 2005 | 08:09 PM
Vaudeville Villain's Avatar
Deep ish, eh Kev? You fixed it in an hour!
Old Apr 4, 2005 | 08:27 PM
lex4style's Avatar
i had a same problem a while back.
Old Apr 4, 2005 | 11:30 PM
MaXiMaGiRL's Avatar
usually happens to me.
Old Apr 5, 2005 | 12:35 AM
beegeezy's Avatar
Is this a performance ecu thing...or something that happens to the stock ecu by itself?
Old Apr 5, 2005 | 11:24 AM
Kevlo911's Avatar
Kevlo for President
I was in the college parking lot for an hour before that trying to figure out what was wrong before me and my friends towed it to my house
Lakersallday24
Jun 16, 2019 01:35 AM
mpbclutch33
Aug 25, 2015 06:23 AM
Samedi
Aug 13, 2015 04:05 PM
niZ
Aug 7, 2015 10:18 PM
