B pillar question
Old Apr 6, 2005 | 02:35 PM
blackmxma's Avatar
B pillar question
I've been searching around on removing the b pillars where the seatbelts are. everyone seems to say its really easy but I must be an idiot cuz I can't figure it out. can anyone help me out?
Old Apr 6, 2005 | 02:42 PM
PAREDLINE's Avatar
Do you know this is an integral body part that is riveted and/or spot welded to the unibody subframe?
To take out the B Pillar you need to remove the entire half of the interior, carpet, headliner and sunroof if you have one. Then drill out each spot weld with a spot weld drill bit or drill through it with a regular drill bit.
Its not easy. It's very time consuming and you'll need a spot welder to get it back together
Old Apr 6, 2005 | 02:44 PM
blackmxma's Avatar
I apologize. I didn't mean the entire b pillar, I'm just talkin about the trim on it behind the seat belt. should have been more clear....
Old Apr 6, 2005 | 02:48 PM
95bkackmax18s's Avatar
yea, you have to take off the piece under it ( it divides the doors) you know which one? pull it out and undo your seat belt and pull out that piece, ( b pillar piece)its not to hard. its been a while since i did it, but thats about all there is.....
Old Apr 6, 2005 | 03:04 PM
99se5spd's Avatar
small screwdriver pry off the cover over the seatbelt on the top half remove seatbelt (14mm for both top and bottom) pop off lower piece and than top piece, there might be a screw in the bottom of the top piece behind the lower piece i dont remember
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
