Rotors & Brake fluid
Old May 8, 2001 | 04:13 PM
danielbu's Avatar
I am looking into replacing my stock rotors, and for the price of OEM it seems that I could get something better. What do you recommend as far as high performance/slotted rotors at a decent price? Dot 4 brake fluid suggestions?
Thanks,
Dan
PS, everyone thanks for your input, I am working towards a lot of work on my max, and you all are very helpful
Old May 8, 2001 | 05:52 PM
Chunger's Avatar
My other car is a Hybrid
For performance.... just get a set of good brake pads such as the Porterfields... especially if you don't need to get new rotors (you can turn them if you have sufficient material left and they aren't damaged).
The rest is just for looks for the most part...
Old May 9, 2001 | 04:39 AM
Enduro's Avatar
Originally posted by Chunger
...(you can turn them if you have sufficient material left and they aren't damaged).
Chunger what do you mean by turning them? Do you mean simply slide the rotors out, flip them and reinstall?
Old May 9, 2001 | 05:42 AM
Lovejoy's Avatar
What he means is that the shop will put them on a lathe and cut away some material so that the surface is even across the face of the rotor, so the pads will bed themselves properly.
Lovejoy
Old May 9, 2001 | 05:55 AM
deezo's Avatar
You have to admit that cross drilled and vented rotors keep the pads cleaner and cooler than stock tho.
Old May 9, 2001 | 11:08 AM
Enduro's Avatar
Lovejoy
Oh ic..cool thanks!
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
