oxygen sensors on manifold
Old Apr 8, 2005 | 02:41 PM
exit10's Avatar
can anybody please direct me as to where the 2 oxygen sensors are on the manifold? i order them just now from oxygen sensors.com i bought the ones where you need to splice the 3 wires yourself. thanks
Old Apr 8, 2005 | 05:32 PM
exit10's Avatar
can anybody help me out?
Old Apr 8, 2005 | 05:50 PM
Bobo's Avatar
See section 6 - 14 of the Haynes manual. 1995 and later models are equipped with two upstream (one per cylinder bank) and one downstream oxygen sensor. The upstream oxygen sensor are located in the exhaust pipe between the exhaust manifold and the catalytic convertor. I believe this is the y-pipe. When I had my Budget y-pipe installed last June, the mechanic removed the oxygen sensor(s) from the OEM y-pipe and inserted them in the Budget Y-pipe. See pictures 12.6a and 12.6b in section 6-14 of the Haynes manual.
This manual is something you should have if you are going to attempt any mechanical work of any complexity on your own. The manual is fairly inexpensive.
I suspect someone may post pictures or something more definitive that has already appeared on the .org before.
my03maxima
Jul 28, 2024 07:40 AM
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
