0503 "Front Right Heated O2 sensor"
Old Apr 10, 2005 | 06:10 PM
apeg's Avatar
0503 "Front Right Heated O2 sensor" <-- that’s the error just got the engine light early 2day
I knew something was wrong because I have been getting rough starts for the last week or so.
Any advice on doing this myself? Should I try it? Or have it done?
Old Apr 10, 2005 | 07:27 PM
99se5spd's Avatar
you cant always rely on pictures on a website, bosch is the factory one, you can see if there is a number on the one in the car to see if it matches, otherwise call them to be sure. you can also check out oxygensensors.com and supposedly if you let them know your on the .org you get 10% (?) off.
Old Apr 10, 2005 | 08:06 PM
apeg's Avatar
thanx 99se5spd i will try that for purchasing
Old Apr 10, 2005 | 08:09 PM
Intel's Avatar
It isn't that hard of a job if you get the plug and play ones that dont require rewiring etc. Just have to get the car on jackstands and then get a wrench or o2 socket on the sensor and remove it. Since you don't have an aftermarket Y-pipe it might be a little more difficult due to the pre-cats/heat shielding.
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
jfl330
Sep 4, 2015 01:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
