this morning! no start!
Old Apr 11, 2005 | 06:54 AM
sohailnz's Avatar
as usual! not leaving home until the last moment for work, i get in my car to start it ... the engine make is making a usual sound but is not cranking it ... need suggestions ... what could be wrong .. i would like to fix it myself . thanks i have 95 maxima gle
Old Apr 11, 2005 | 07:41 AM
yeshivishmaxima's Avatar
There are a few thing it can be. 1)fuel pump fuse. (easy)
2)fuel pump not good ($$$) it is under passenger seat.
3)youre outta gas!!!
Old Apr 11, 2005 | 07:51 AM
sohailnz's Avatar
the car has a full tank .. the feeling that i am getting is that the car is trying to start sound being generated but it does not seem to be turning the motor ... do you think a belt might be broken? or something that is not rotating the engine ...
Old Apr 11, 2005 | 10:01 AM
sohailnz's Avatar
does any one know an answer to this... why the car is making a sound as if it trying to start but not rotating the engine.. it makes a sound but you dont feel any vibration??? plz i wanna know what needs to be done ... whether to buy a new car vs fix it ..
Old Apr 11, 2005 | 10:13 AM
did u check fuses
Old Apr 11, 2005 | 10:14 AM
p00tan6's Avatar
check the battery cables
Old Apr 11, 2005 | 10:19 AM
sohailnz's Avatar
the battery is fine and the fuses are fine ... somehow it is not rotating the engine or something ... i hope nothing is broken inside ...
Old Apr 11, 2005 | 11:11 AM
kormax97
same thing happen to me yesterday. try leaving the A/C to off before you start. it worked for me...
Old Apr 11, 2005 | 11:23 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Maybe your starter is bad. What I understand from your post is that you are cranking, but the engine is not actually moving. Can you verify this?
Old Apr 11, 2005 | 12:30 PM
sohailnz's Avatar
yes exactly .... i jumped the battery using the other car and after several repeated attempts it started but there was a shrill belt like sound that kept on coming and then vanished .. now i am driving it but worried if it happens again !
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
