installing leater seats
Old Apr 11, 2005 | 01:38 PM
yeshivishmaxima's Avatar
hi i bought some leather seat covers for my 99 maxima and i need help installing
1) how do you remove the plastic head rest holders in front seats
2) how do you remove rear seat backs
3)can you unscrew lumbar handle from drivers seat
thanks.
Old Apr 11, 2005 | 01:53 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
1. take off the heads and pop them off with a flat head.
2. there are 2 bolts on the bottom that you loosen and there are hooks on the top. lift up and pull off.
3. yes
good luck
Old Apr 11, 2005 | 02:57 PM
hi thanks, i can't seem to get the back of the back seat off. i unscrewed two bolts from bottom of seat and unhooked two hooks but it is stuck in the middle. do i have to unsrew the plastic cover behind arm rest?
please help?
also the headrest holders wont come out from front seats.
Old Apr 11, 2005 | 03:29 PM
please help me remove the back par ot the back seats
Old Apr 11, 2005 | 05:23 PM
99se5spd's Avatar
okay here goes..
1. after removing the panel on the back of the seat reach up to the underside of the headrest posts (after removing the headrest) and you will feel/see where they come out of a hole in the frame, push these 2 tabs, id guess you would call them, together and push up, if its hard to do you can use a deep 12mm with an extension on them and whack them with a hammer.
2. rear seat backs, ther is a piece of vinyl that connects the armrest to the seat itself, follow it back and it ends in a plastic clip that clips onto the bottom of the access hole, lift it up and there are 2 10mm/phillips screws there.
3. the lumbar handle: push the foam on the side of the seat in so you can see behind the handle there is a "c" clip there, using a hook of some sort hook it where the handle extends(where you grab it to adjust it) and pull out(it might also be 180 degrees from there, you have to get it at the right position, just like manual window crank) careful though it will go flying, keep an eye on it.
any other questions let me know, i do leather interiors for a living.
Old Apr 11, 2005 | 05:28 PM
97maximaman's Avatar
just out of curiosity, what does a lumbar handle do, and how do you use it??
Old Apr 11, 2005 | 06:22 PM
PAREDLINE's Avatar
It brings a big bulge to the back of your rectum
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
lowpost99
Sep 8, 2015 05:06 AM
GregL65
Sep 5, 2015 09:37 PM
Johnny9595
Sep 3, 2015 05:18 AM
