any place online to buy the following?
Old Apr 11, 2005 | 04:08 PM
ShRapNeR's Avatar
Throttle Position Sensor
Purge Control Valve
had diagnostics run at stealership and these came up..... or so they say... i know i have an 1008 code but they didn't say anything about it, atleast not that i know of.
said the purge control valve was on top of the fuel tank (wtf, unless it is ofcourse)
and i don't know why the tps would be bad.. unless me adjusting the throttle cables has something to do with it..
any help on these would be appreciated...
also.. i asked about the metal grinding i hear when i put in gear.. they said something inside my tranny... anyone have any idea what it could be? anything that usually goes wrong first on 96 models or anything..
thnx.
Old Apr 11, 2005 | 04:20 PM
ShRapNeR's Avatar
add an Ignition Switch to the list.
Old Apr 11, 2005 | 04:47 PM
dgeesaman's Avatar
Maintenance Monster
http://www.trademotion.com/partlocat...cfm?siteid=840
Old Apr 11, 2005 | 06:34 PM
ShRapNeR's Avatar
thnx...
anymore places....
and where is this "purge control valve" located
Old Apr 11, 2005 | 08:07 PM
ShRapNeR's Avatar
to page one
Old Apr 12, 2005 | 05:16 AM
ShRapNeR's Avatar
last bump to one
Old Apr 12, 2005 | 05:31 AM
dgeesaman's Avatar
Maintenance Monster
What are you bumping for? Your thread title says you want an online parts store, and you got one.
Put each question in a separate thread with a good title and you'll get better results.
- metal grinding sounds in a manual transmission mean a bearing or synchro failure. If the grinding sound happens regardless of gear or speed, you may have the famous differential carrier bearing failure. If it's only when going into one particular gear, it's probably the synchro. You can confirm it's the synchro if double-clutching stops the grinding sound (double clutch = clutch in, shift to N, clutch out, clutch in, shift to next gear, clutch out). The double-clutch will allow you to drive with the problem indefinitely, but to fix it involves a tranny rebuild.
- the purge control valve is aka the fuel tank vent valve on Concelli's site.
- get a multimeter and do the TPS adjustment before replacing it.
Dave
Old Apr 12, 2005 | 06:23 AM
Zack342's Avatar
you can buy them used from me
Old Apr 12, 2005 | 02:36 PM
ShRapNeR's Avatar
Dave
im an automatic...
and what relation of tps have to do w/ 4th gear malfunction.. like what could cause it to show up.... nissan said i need a new tps sensor yet i pull the codes when i get home and its 4th gear malfunction .. i want to know how they got their results..
and when they say purge control valve.. do they mean the one attatched to that black box under the car in the back or the one next to the throttle body?
also... if the tps dosen't make 1106 come up somehow .. how come they didn't tell me my trans was messed up when i took it to them?
Old Apr 12, 2005 | 05:42 PM
dgeesaman's Avatar
Maintenance Monster
I looked up the purge control valve, and indeed it's up by the throttle body. The charcoal canister itself is stuck back by the fuel filler neck.
Also, it's not often the dealer gets accused of knowing more about the car than they should. Because they don't have to be good, they just have to be polite.
Dave
Old Apr 12, 2005 | 05:54 PM
ShRapNeR's Avatar
ok... is that the EGR or the EVAP?
does the egr one have to do with emissions?
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
James92SE
Oct 8, 2015 04:57 PM
Junebug1701
Sep 25, 2015 01:54 PM
