Swapping Tail Lights???
Old Apr 12, 2005 | 06:49 PM
BLINGBLING's Avatar
will tail lights from a 98 maxima fit my 95 maxima??
Old Apr 12, 2005 | 06:52 PM
CleanMAX98's Avatar
no. the bumpers are different
Old Apr 12, 2005 | 07:09 PM
rome06's Avatar
no im pretty sure its shaped differently and also reverse lights are on botton on 97-99's
Magikone69's Avatar
it has nothing to do with bumpers, the outter tails will fit, the inners will not, you will need the 97+ trunk to fit the inner tails.
Old Apr 12, 2005 | 07:14 PM
rome06's Avatar
yah b/c the trunk is shaped differently right?
Old Apr 12, 2005 | 07:19 PM
Magikone69's Avatar
the shape of the inner tails ar differemt, the dimensions of the lights. i have a 95 and did the 97 swap to fit the 97 lights. check my cardomain for a few pics.
Old Apr 13, 2005 | 09:47 AM
FloodShark's Avatar
Will a 97-99 trunk directly bolt onto a 95-96? Or do you need the rear bumper as well to go with it?
Old Apr 13, 2005 | 09:50 AM
jblinga's Avatar
Its just the trunk lid. Everything bolts on. I have plans for 97-99 trunk lid & smoked 97-99 red/clears
Old Apr 13, 2005 | 09:55 AM
Magikone69's Avatar
yea just the lid, be warned tho, u may want to take the bottom latch from the 97+ car with you. when i installed my trunk lid, the stock latch on my 95 wasnot locking the lid shut when i closed it, i tried everything, even raising the latch up more. i went back and bought the new bottom latch from the same car i got the lid from and every thing locked perfectly.
buy the latch just in case, it should be only 15-20 bux and its worth it just in case the stock one doesnt work, u never know when u may run upon another 978+ latch.
Old Apr 13, 2005 | 09:58 AM
FloodShark's Avatar
There's a ton of 97+ maxima's with perfect condition rear ends just chilling at a junkyard I went to the other day so getting the trunk and latch should be nooo problem.
Now I just gotta find a place that has DP0 Nissan Paint to match the trunk to my car.
Old Apr 13, 2005 | 10:05 AM
2 Da Max's Avatar
go to paintscratch.com, or i think lanka
Old Apr 13, 2005 | 12:34 PM
DRIFFT MAX
Ok here is how it is 95-96 trunks have a roll near the bottom of the trunk and that is also incorporated in the taillights and the innertails are a lil different in shape.
97-99 have no roll, it is a flat trunk, and the taillights are flat too.
Old Apr 14, 2005 | 03:03 PM
BLINGBLING's Avatar
thanks for all the info. i will look for a trunk and see if i convert.
Old Apr 14, 2005 | 06:35 PM
QuickFast's Avatar
What I dont get is how will changing the trunk lid from a 95/96 to a 97-99 get you to be able to use the red/clear tails when the amber part on the 95/96 isnt on the trunk, but on the outside set.
Old Apr 14, 2005 | 06:46 PM
DRIFFT MAX
look at the red clears before you ask that question and it should answer itself.
vingodine
45
May 21, 2016 12:46 PM
tommy20020
Jan 6, 2016 04:05 PM
4doorGTR
Sep 11, 2015 04:09 PM
220k+ A32
Aug 17, 2015 03:57 PM
Blackwind
Aug 5, 2015 06:35 PM
