Turn signals don't work! Help!
Old Apr 14, 2005 | 02:10 PM
RichMax's Avatar
Boosted like Snipes tax refund
Turn signals (front and rear) don't work. There is no signal on the dash, and no sound, either. This holds true of the hazard warning signal as well, of course. I suspect a relay, but can anyone confirm? Anything else I should consider?
Old Apr 14, 2005 | 02:14 PM
Black Maxima
Your signals will not work if your Hazard button is unplugged. Check to see if that is still plugged in or maybe you will need a new Hazard switch.
Old Apr 14, 2005 | 02:46 PM
RichMax's Avatar
Thanks a lot for advising of the possibility, but I'm not sure how it could have suddenly become unplugged...
Old Apr 14, 2005 | 03:05 PM
Black Maxima
Yea, I know that's strange...
Old Apr 14, 2005 | 04:17 PM
Northern Maxima's Avatar
Same thing happened on our old Blazer and it did turn out to be the relay switch.
Old Apr 14, 2005 | 06:38 PM
RichMax's Avatar
any other thoughts before I go out and buy a relay?
Old Apr 14, 2005 | 06:56 PM
Nismotic's Avatar
Always sunny in philly
It may be a simple fuse. Same thing happened to me a while back.
Old Apr 14, 2005 | 07:00 PM
goldmax's Avatar
I just put in a post for my parking lights suddenly going out while I was driving last night! I'm suspecting a relay problem also.
Old Apr 14, 2005 | 07:09 PM
95bkackmax18s's Avatar
yep, very true. happened to me too a while back and it was the fuse. did you even check the fuse?
Old Apr 14, 2005 | 07:15 PM
2 Da Max's Avatar
you need to refill the blinker fluid......duhh
Old Apr 14, 2005 | 07:23 PM
RichMax's Avatar
fuse, eh?
hadn't given that a check...
nah.. i topped off the blinker fluid when I had the stereo lubricant replaced..
Old Apr 15, 2005 | 07:19 AM
RichMax's Avatar
I've checked the fuses... no problem with the fuses...
Any other ideas?
Old Apr 15, 2005 | 08:28 AM
kormax97
use your arm out the window when you make a turn..
you know.. raise up, down, straight out...
Old Apr 15, 2005 | 09:15 AM
RichMax's Avatar
I'm not going to be to harsh on the last guy... just don't end up behind me right before I make a turn.
I am trying to find out how to diagnose a short in the lines to my signals and how to fix it, because the fuses seem to work fine, and I am fairly certain the flasher unit works properly as well...
Old Apr 15, 2005 | 01:45 PM
RichMax's Avatar
The flasher unit (the "switch") was malfunctioning...
Old Apr 15, 2005 | 01:46 PM
Black Maxima
Old Apr 15, 2005 | 02:52 PM
DAVE Sz's Avatar
Hooooooonda.....
Shhh, didn't you know most people on this board are too stupid and lazy to think for themselves.
Old Apr 15, 2005 | 07:20 PM
Nismotic's Avatar
10 charac....
Old Apr 17, 2005 | 02:17 PM
Neem's Avatar
You probably need a new flasher replaced. It's fairly inexpensive because I've had my flasher replaced on my 96 Max and it cost me @ $90.00
trasmadean
Feb 1, 2017 08:20 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
beboski
Aug 16, 2015 05:23 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
