Replaced alternator, car now squeals
Old Apr 14, 2005 | 08:39 PM
THT's Avatar
THT
Throbbing member
Okay, I replaced my alternator today (and have the cut hands to prove it). However, now, the car intermittently squeals. I know it's coming from the idler pulley. When I reinstalled the pulley, I pushed down on it from above, leaning my body weight against it to push it down as far as I could as I tightened it with my other hand. My question is, what's the best way to install the pulley so I avoid this problem? Or, is there another possible cause of this squeal?
~THT
Old Apr 15, 2005 | 04:53 AM
THT's Avatar
THT
Throbbing member
Bump TTT
~THT
Old Apr 15, 2005 | 05:09 AM
dgeesaman's Avatar
Maintenance Monster
It is tightened against the block, right?
I use this order:
1) loosen idler pulley center bolt
2) loosen idler pulley adjust bolt
3) adjust belts/change alt. etc
4) tighten idler pulley center bolt until there is no wiggle in the pulley, but not tight enough to put stress on the adjust bolt.
5) tighten adjust bolt
6) snug idler pulley
Sometimes I get lazy and do things out of order - it always makes a mess.
Dave
Old Apr 15, 2005 | 06:28 AM
Loe max's Avatar
~THT
Which bolt are you tightening? The center bolt that holds the idler pulley in? or the adjustment bolt that runs up along side the engine block to a 'stopper' that allows the pulley to be adjusted?
Old Apr 15, 2005 | 06:58 AM
THT's Avatar
THT
Throbbing member
Both the idle pulley bolt and the 14mm adjuster
~THT
Old Apr 15, 2005 | 07:26 AM
Loe max's Avatar
~THT
try loosening the 14mm adjuster and idler pulley bolt again. If the idler pulley bolt is on too tight, then the 14mm adjuster won't even do its job. Now use the 14mm adjuster to tighten it. Then finally go ahead and tighten the idler pulley bolt and see if that helps.
Old Apr 15, 2005 | 07:28 AM
Loe max's Avatar
My other question is did you reassemble the idler pulley correctly?
It should go in this order from right to left (view from front of car):
-The big long washer
-14mm adjuster rod
-idler pulley
-smaller washer
-that black plate
-bolt to hold it in.
Old Apr 15, 2005 | 07:51 AM
THT's Avatar
THT
Throbbing member
This was my problem. No more squealing! Thanks guys!
~THT
Lakersallday24
Jun 16, 2019 01:35 AM
PH98I30
19
Jun 13, 2016 02:38 PM
Balkins
Feb 1, 2016 12:45 AM
02PearlSE
Oct 7, 2015 02:12 AM
Samedi
Aug 13, 2015 04:05 PM
