I got the following CEL, Please help
I got the following lights right after putting back together my air intake, since I had to remove it to get to the starter I changed.
1.Code 0503 Upstream oxygen sensor or circuit fault (right bank)
2.Code 0303 Upstream oxygen sensor or circuit fault (left Bank)
And this one I already had before
3. Code 0204 Kock sensor or circuit fault
Any translation of what the first two mean?
What can I check first?
did you triple check all those connections you took off the intake when reassembling? make sure no wires pulled loose of the harness or anything... i had one wire pull out of its seating in the harness but wasnt visible, took awhile to catch that.
My CEL light came on last a week ago this past Wednesday. I read the stickies on how to get the code and was given 0413, 4 long, 13 short. Looked it up and found that there is no such code. I reset the engine light and hasn't come on since.Something must have tripped it.
jmlee44
10-02-2022 02:13 PM
JoshG
51
09-21-2015 10:41 PM
ballerchris510
09-10-2015 09:35 PM
