Alternator/AC Compressor Belt Replacement ?
Hi-
Well I replaced the belt that connects the alternator and ac compressor to the drive shaft. I ran over something and heard a clunk then the belt tears and rips and falls apart. I replaced it with a Gatorback belt that I bought from Autozone. I've read that you should just tighten the belt until it stops to squeal, correct?
Well my belt only squeals when I have the AC on so I tighten the belt and it goes away. After a little bit the belt will squeal again. Can you tighten the adjuster too tight? I just want to make sure that I'm not making it to tight and screwing up the belt somehow.
Any help would be appreciated. Thanks!
TJ
TJ
lowpost99
Oct 26, 2025 06:53 PM
tsi6001
Oct 3, 2022 10:23 PM
