FSTB and RSB... are all created equal?
Yes, i posted this in the General forum, but i wanted the maximum response before i order them tomorrow...
Im buying front strut tower bar and rear sway bar tomorrow... im going with the cattman FSTB and probably the
Addco RSB. does anyone have any compelling reason i should or shouldnt go with these? i heard somewehre the stillen
RSB has more adjustment... but its also quite a bit more money correct? im assuming all FSTBs are basically equal...
as long as they arent made of plastic or toothpicks or some other weak material. any comments are appreciated.
Neal
Neal
Go with the Vibrant strut bar from Streetbeat. It's cheap, and it does the job great. I don't see a point in spending all that extra money. Rsb, go with stillen, from what I have heard, it is better. Only problem is they are on back order, I have been trying to get one for about a week now.
Good luck
K
Good luck
K
Neal
Neal
Addco RSB question
For those with one, because in mounts under the rear axle, does this mean you can no longer use this as a rear jack pt?
I ordered mine from Morgan Performance where you'll save a few bucks since they ship direct from factory, but it takes a while! So far, it's been a week and a half and no word of shipment...
Re: Rear STB, most say it makes minimal difference.
Front strut tower braces all do the same thing, and they're all pretty strong... I would definitely get it... makes a huge difference in the overall handling balance of the car (I feel a little less understeer, a little less yaw movement from the REAR, and less creaking noise when I drive up driveways at an angle).
Rear strut tower - couldn't feel much difference performance wise, but did make a slight differnce in body rigidity (less rear flex/creaking noises from the package shelf). I think it'd make more of a difference for hatchbacks and car where the rear sit flips down since there's less metal bracing back there.
RSB, don't know... don't have one yet... I drive pretty hard, and the RSB will make the car corner harder up to the limit, but won't be as forgiving at the limit. Less progressive breakaway, and may make the back more prone to come around. In a Miata, at an autocross, it made the car less progressive... it would hold hold hold, then spin.
-V
-V
Thanks everyone
Thanks to everyone for their advice... i ordered the Stillen RSB (its on a bit of a backorder) and the procarparts.com strut bar (as well as some other stuff.. spent some $$$ today.) anyhow, thankyou for responding. happy driving.
Neal
Neal
Agree..StreetBeat/Vibrant and Stillen RSB
Good luck
K
Good luck
K
Cheers
Re: Agree..StreetBeat/Vibrant and Stillen RSB
Originally posted by zagato27
Agree, go with the StreetBeat/Vibrant FSTB and then the Stillen RSB. I've got the StreetBeat/Vibrant and it's great. Looks good, well made and works. I'm saving for the Stillen RSB. I think that it is better made and another plus...adjustable. Just can't get enthused about the ADDCO...looks cheap.
Cheers
Cheers
Re: Re: Agree..StreetBeat/Vibrant and Stillen RSB
Originally posted by KCTYPHOON
your funny.. lmao... the addco rsb looks cheap, but the $35 fstb is great quality and well made.. oh boy..
Yup, still a little bit hard to explain.
Yes, the StreetBeat is well made.
Cheers
