weird problem
Old Apr 18, 2005 | 12:45 PM
9maxima5's Avatar
weird problem
Guys when i an driving on any road my car will all of a sudden like drop rpm's and then hesitate until i hit the gas a little more than it all goes away. It doesn't do it when the engine is cold any reasons? Iacv valve? It is real annoying and it happens like all the times. Thanks in advance
Old Apr 18, 2005 | 01:13 PM
aleveran's Avatar
Any ECU codes?
Old Apr 18, 2005 | 01:20 PM
cam_honestiam's Avatar
Tough to diagnose with only those symptoms. Stick or Auto? When does this happen: all the time, when you are accelerating/decelerating?
Old Apr 18, 2005 | 01:26 PM
9maxima5's Avatar
no codes its an auto it happens when i do both accererate and when i just keep the pedal steady.
Old Apr 18, 2005 | 01:30 PM
aleveran's Avatar
Does your problem reproducible constantly? Did you use low grade fuel recently?
Old Apr 18, 2005 | 01:32 PM
9maxima5's Avatar
nope i use 93 and it does it all the damn time
Old Apr 18, 2005 | 01:37 PM
aleveran's Avatar
If you say ‘check engine light’ is not on, than the knock sensor alone is the only one that will not cause ‘check engine light’ to show up. Did you try to read ECU codes anyway?
Old Apr 18, 2005 | 01:41 PM
aleveran's Avatar
Currently I’m dealing with hesitation during acceleration problem. But I got codes:
09 01 - Front Right Htd 02 sensor heater
03 04 - Knock Sensor
10 08 - EVAP canister purge volume control valve
01 01 - Camshaft Position Sensor
0101 - is most likely the one responsible for it.
Old Apr 18, 2005 | 01:53 PM
9maxima5's Avatar
I went to the dealer the other day and the only code was knock sensor. Could that be the problem?
Old Apr 18, 2005 | 02:20 PM
aleveran's Avatar
At some extend, Yes.
If knock sensor recorded by ECU the engine goes on the ‘save mode’ and that could affect performance. Try to reset ECU and see if it helps.
Also, search threads about knock sensor problem. Where are lots of threads on this.
Old Apr 18, 2005 | 04:55 PM
9maxima5's Avatar
thanks alerveran but I did do some research and i couldn't find nothin that makes the sensor do this to the car. Weird *** stuff but thans again u been a good help.
Old Apr 19, 2005 | 06:34 PM
9maxima5's Avatar
bump bump...
Old Apr 19, 2005 | 08:04 PM
killerVQ30DE's Avatar
Ahemm Safe mode
Old Apr 19, 2005 | 08:53 PM
konak85's Avatar
Spark plugs, MAF?
AaronL
Nov 15, 2020 11:52 AM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
