JackPot!!!!!!!!!!
Old Apr 19, 2005 | 07:00 AM
JDM_Maxima's Avatar
JackPot!!!!!!!!!!
well......... sorta
i got a CEL for 0111 EVAP control system/Flow
anyone have any luck with finding out this problem and sloving it.
what kind of harm can this do if left unchecked?
i havent noticed any problems drivability wise.
thanx to anyone who can shead light on my prob.
Old Apr 19, 2005 | 10:06 AM
Nismotic's Avatar
Always sunny in philly
Originally Posted by JDM_Maxima
well......... sorta
its one of the hardest codes to diagnose. There is an evap leak somewhere on your car. In order to find out where it exactly is, you must take it to the garage and get a smoke test done to see where the leak is coming from.
you will not pass inspection, and your CEL light will become the death of you.
I've had it for almost a year now...
Old Apr 19, 2005 | 02:06 PM
JDM_Maxima's Avatar
thanx for the info
Old Apr 29, 2005 | 07:48 AM
3Mar67's Avatar
I've got the same code.
Anyone have any updates on solving this?
Old Apr 29, 2005 | 03:11 PM
JDM_Maxima's Avatar
no up dates yet. fortunately, when i went to check my check engine light just to make sure no other codes came up. the code 0111 went away. hopefully it will not rear its ugly head again, (knock on wood)
Old Apr 30, 2005 | 08:33 AM
the_3d_man's Avatar
I just recently had that code. It was so simple i couldn't believe it. I put on my strut bar and the bar was rubbing on the little vacuume hose that connects to the evap valve thing (i dunno what it's for) and a hole wore in the line. I just bent the metal line and put a new hose on and it was fixed. I can post pics if you want.
Old Apr 30, 2005 | 12:34 PM
96ItaliaSE's Avatar
il massimi bassi
i had that code combined with EVAP valve. I clean the EVAP with PB BLASTER now I get code 0705 only...hmmm i will buy the valve and canister I just wanna know if the PB blaster actually did anything
Old Apr 30, 2005 | 01:30 PM
JetBlackMax83's Avatar
Think my code was 0419 dont really remember swapped out my evap valve and no codey no more
Old Apr 30, 2005 | 05:08 PM
3Mar67's Avatar
I need a new EVAP Purge Control Valve
Does anyone know the differences between these two Nissan part numbers?
149303M201
1495635U10
They're bost listed as purge control valves, but one is way more expensive than the other.
Thanks for any help
Old Apr 30, 2005 | 06:26 PM
96ItaliaSE's Avatar
il massimi bassi
one is for cali emissions vs. Federal spec maybe....
Old May 1, 2005 | 03:08 PM
vqssl2914's Avatar
I'm a little new to this. What does CEL & EVAP stand for?
Old May 1, 2005 | 03:29 PM
killerVQ30DE's Avatar
Did everyone forget this thread !?!?!
http://forums.maxima.org/showthread.php?t=211145
Old May 1, 2005 | 03:43 PM
thumper10s's Avatar
there is some one on the forums that has a link in their sig that has a very detailed list of how to track down the problems from the source, if anyone knows who it is post it here, ill try to find it soon
MAXecutive
20
May 19, 2020 03:01 AM
sean05
Jan 10, 2007 12:40 PM
