4th gen using 5th gen clutch
Old Apr 19, 2005 | 09:06 PM
dawalkster's Avatar
is craving Bojangles
my tranny is going in to be serviced soon so i might as well replace the stock clutch since it already has 129k miles on it. a few other members suggested that a 5th gen clutch is a very nice clutch to get since its got a bit more bite then the stock 4th gen which makes it very streetable but also good if you have a few mods or tend to be a little harsh on it everynow and then. some other options would be for me to just stick with a new stocker, or go the aftermarket route with exedy or an act stage 1.
whats everyones opinions on these clutches? especially a 4th gener using a 5th gen clutch.
Old Apr 20, 2005 | 06:23 AM
BigLou93SE's Avatar
I have the 5th gen. and would strongly recomend it. It feels great, and engagement is smooth. I haven't been to the track yet, but 1-2 and 2-3 feel great. 5th gen. is just about the same amount of money as 4th gen., maybe a few dollars less actually, but for the better clamping force, why not? Again, I love this setup, and suggest that you look into it.
Old Apr 20, 2005 | 08:27 AM
Gmahoney's Avatar
What parts do you need anyone able to lay it out im wanting to purchase them as well.
Old Apr 20, 2005 | 09:30 AM
BigLou93SE's Avatar
You need a TO bearing, clutch disk, and pressure plate/clutch cover. Check this thread.
http://forums.maxima.org/showthread.php?t=357673
and this one
http://forums.maxima.org/showthread.php?t=360332
Old Apr 20, 2005 | 05:54 PM
maximazation's Avatar
my next clutch is going to be the 5th gen clutch, went to the local nissan dealer and found out its $268 for all the parts for the clutch including pressure plate, bearings.etc, plus i get a 30% off that $268 cuz my dad owns a body shop..lucky me.
Old Apr 20, 2005 | 07:27 PM
dawalkster's Avatar
great, i think this is what im going to use then. does it matter the year, or is any year 5th gen clutch ok?
Old Apr 20, 2005 | 07:38 PM
MDeezy's Avatar
2000 or 2001.
You should be able to get all the parts for a little over $200 on jerryrome nissan.
Old Apr 20, 2005 | 07:41 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
i also have the 5th gen setup in my car. 5th gen PP, disc and TO bearing cost $200. i love it, grips great, defifnately worth the money.
Old Apr 24, 2005 | 05:20 PM
Keatz's Avatar
Hey guys, im new here and dont really know much about the maxima, i have a 98 GXE 5spd and i got tranny issues. I wanted to know if the 5th gen clutch and tranny can be used directly on mine wihtout modification?????
Old Apr 24, 2005 | 05:34 PM
MDeezy's Avatar
5th gen clutch and tranny will bolt up perfectly no modifications needed at all.
Old Apr 24, 2005 | 07:05 PM
RA030726's Avatar
I'm nutty for Nissans
use a 2000 for the parts. the 2k1 has a smaller disk....which is not good.
Old Apr 25, 2005 | 12:51 PM
Keatz's Avatar
I went to the nissan dealer and the mechanic said to see if i would need a new flywheel that would fit the 5th gen, is that true or will my 98 work??????
If i can get a tranny, should i go with a LSD??? and what year is preferrable, 2000 or 2001?
Old Apr 25, 2005 | 06:40 PM
Keatz's Avatar
Hey guys, just got a few more quick questions, do the SE transmissions on the 5th gen have LSD??? And i've heard that the tranny shifter sits closer to the dashboard, wont that affect my linkage????
If anyone has done this mod, tranny and clutch from a 5th gen. onto 4th gen, if u can give me some pointers as to what to tell my mechanic, tips or things to look out for, so he stops freaking out about this, it would be great, thanks. Sorry for the bother im new at this, but i just wanna make sure i get it done right, thanks again
Old Apr 25, 2005 | 07:56 PM
MDeezy's Avatar
Use a 2000 Model year transmission and clutch. There is a LSD version of the tranny but is very hard to find. If you manage to find it you will need new axles as the axle inputs to the tranny are about twice as large.
You dont need a new flywheel for the 5th gen clutch, or tranny the 5th gen tranny has the exact same part number as the 4th gen.
You dont need to tell you mechanic anything as long as he knows how to install a transmission then that is it, its a directly bolts up, no modification needed what so ever. I've heard that the shifter will sit a bit further back, but its not too noticable.
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
220k+ A32
Sep 11, 2015 02:18 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
