Why are my brakes squeeking?
Old Apr 20, 2005 | 08:47 AM
dki378's Avatar
My brakes pads have more than enough padding left and my rotors (4 wheel discs) are in very good condition. Although I did just recently get my rotors turned. Do any of you have any helpful suggestions to get rid of this noise? The sound only comes out when the pads first make contact with the rotors. Otherwise it is very quiet. Any thoughts?
Old Apr 20, 2005 | 09:13 AM
BrentK7's Avatar
not to sure, but perhaps (if u just got them turned) they need time to reseat the pads to the disc.
Old Apr 20, 2005 | 09:28 AM
CreativeDesignz's Avatar
you might just hafta clean them there might be some brake dust causing some unwanted noise. Check the shims as well.
Old Apr 20, 2005 | 09:33 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
if you got cheap pads. then they will squeek.
Old Apr 20, 2005 | 10:02 AM
dki378's Avatar
I've tried brake cleaner on all 4 brakes but the noise it still there. Have any of your tried the CRC BRake Quiet product?
Old Apr 20, 2005 | 10:48 AM
nd4spdgt's Avatar
http://www.stoptech.com/whitepapers/bedintheory.htm
Old Apr 21, 2005 | 05:49 AM
konak85's Avatar
Does autozone or Napa carry shims or do you have to get it from dealer? How much do they go for?
Old Apr 21, 2005 | 05:55 AM
nd4spdgt's Avatar
The brake cleaner will just remove the brake dust, won't really make a difference in noise, IMO. Definitely try the brake quiet product. I just replaced my pads yesterday and used the brake quiet between all metal-metal contacts (pads->shims and shims->caliper), needless to say, no squealing. That should do the trick.
If your pads are pretty low (which mine were) the shims may have actually been riding up against the rotor, but I think you said your pads are in good condition, so it's probably just the shims.
Old Apr 21, 2005 | 06:12 AM
yhtan76's Avatar
same thing happened to me. Squeaked since new brakes put in by previous owner. Til today it still squeaked. I even have new rotors as well. I think it just that damn cheap pads.
Old Apr 21, 2005 | 06:50 AM
vqssl2914's Avatar
I've had the same problem... I applied the brake quiet stuff but it just wore off in a couple of months and the squeak came back...
Nissan even put out TSB's on break squealing... I've read them on this forum but they're not much help. It says something about Nissan cutting down on asbestos use and using more semi metallic / ceramics for shims or wutnot... but i think most auto manufacturers use semi metallic materials anyway.
I think the best thing to do is keep applying brake quiet every 3 months or so until you get better quality brakes / shims.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
