how do you take out the actual headlight
Old Apr 20, 2005 | 11:19 AM
CleanMAX98's Avatar
i want to do the AE headlight mod, but i am having trouble getting the housing out, any tips on how to do this?
Old Apr 20, 2005 | 11:22 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Take out the battery and the corner light. You should be able to see the bolts holding it in then.
Old Apr 20, 2005 | 11:26 AM
MDeezy's Avatar
Follow above advice.
Take out batter take out corner lights, then you'll see 2 bolts, take those out, and there are 2 more close to the radiator, you'll prbably need to unbolt the fuse box to get to the bottom bolt ( I always had to). pasensenger side is the same minues fuse box removal.
I recommend baking your headlights with some turkey pot pie, good thing to eat while painting
Old Apr 20, 2005 | 11:32 AM
Caracicatriz's Avatar
What was that?
I took them straight out without removing the outer part and it was the biggest PITA to get back in. Follow the advice above.
Old Apr 20, 2005 | 12:06 PM
Crest Crocodile's Avatar
guys I gotta problem...i was upgrading my stock headlights to some Silverstars, but while I was taking out one of the old headlights on the driver side, I accidently busted the bulb in the housing...now i have a whole bunch of glass and residue inside the housing that I can't get out...what would be the best (easiest!) way to get all of that stuff out??
Old Apr 20, 2005 | 12:07 PM
maximus_96's Avatar
take the whole headlight out and shake the glass bits out
Old Apr 20, 2005 | 12:15 PM
yeah, thats what I tried to do, but I couldn't get the damn headlight cover off...I don't know, maybe I'm doing something wrong...any suggestions on how to get that cover off??
Old Apr 20, 2005 | 12:33 PM
MDeezy's Avatar
what cover the side corner light or the headlight?
Old Apr 20, 2005 | 12:37 PM
the headlight cover...
Old Apr 20, 2005 | 12:45 PM
MDeezy's Avatar
I dont know how to desribe better and I cant find a pic, I'll snap one tommorow if you still havent found out but best I can say is look around, the corner is easy to get but the other two could be tricky to find.
(driver side)stand in front of the head light look behind the head light, to the lest most of the head light you should see some stubby screws the ac line should be kinda in the way.or down by the fuse box in fornt of it you'll see a screw its kinda blocking thats what they look like.
Old Apr 20, 2005 | 01:47 PM
maximus_96's Avatar
getting the cover off will require baking or using a heat gun. taking the headlight out would be easier. start off by taking the corner light out first. then there are two 10mm bolts directly on the side of the headlight housing where the corner light was covering. then directly behind the headlight on the side towards the mid. of the car are two 10mm nuts. also you have to unsnap the grille off the headlight. after that the headlight will come out.
Old Apr 20, 2005 | 02:43 PM
Flava_24/7's Avatar
Boosted Panda
Sledge Hammer
Old Apr 20, 2005 | 03:44 PM
nadir_s's Avatar
vicodin ... gift of life
to clean out the inside of your headlight, use water and put a crumpled paper towel in there and swish it around ... then dump out everything and let it dry.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
