So I just bought an Underdrive Pulley...
Old Apr 23, 2005 | 07:05 PM
ti2tmax's Avatar
Has his VINs memorized
Just a couple Qs. What are HP gains for cat back, intake, clutch and flywheel moded 99? I hardly belive it's anywhere near the 15 that the company claims... And will that prevent my car from shutting down when I pop the clutch in with the radio going while braking to a stop, with lights on? sometimes my RPMs drop too low when I'm doing that and it will just stall out. I thought the flywheel might have helped out with that but it didn't.... Any little things that I should watch for during install? as I will probably do it myself (and a friend). Probably a pulley puller would be a good idea, but what else? do our belts have a tensioner pulley to make taking the belts off and on easier? Thanks all!!
Old Apr 23, 2005 | 07:07 PM
NCSU_MAX's Avatar
Maximoneypit
well i dont personally have one but ive heard that they dont do anything - MAYBE 3-5 hp.
Old Apr 23, 2005 | 07:15 PM
ti2tmax's Avatar
Now is that at the crank, or at the wheels you suppose?
Old Apr 23, 2005 | 08:11 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
i have a upd, my friend installed it for me. it probably adds 1-2 hp, at the wheels, crank, i dont know, either way its insignifigant. if i remember correctly, there is a belt tensioner. you also need to get new belts for the new pully. and it should not effect your electronic systems. mine didnt do anything to my systems.
Old Apr 23, 2005 | 08:16 PM
2 Da Max's Avatar
i think i felt it in my head, as for the rpms i didnt think they reved quicker
Old Apr 23, 2005 | 10:15 PM
RastaManMax's Avatar
The UDP should add a few at the wheels i'm guessing 2-5whp. After you've done most other bolt on mods this is a good one to end the modding with.
LEMAR
Old Apr 24, 2005 | 04:18 AM
maxgtr2000's Avatar
KH3 by popular demand
Underdrive shouldn't hurt unless you're running a heavy system, you gain horses but lose some alternator amperage, nothing to worry about unless you compete in spl. Car shouldn't shut off.
Old Apr 27, 2005 | 06:57 PM
ti2tmax's Avatar
Ok, well right now sometimes if I'm revving at 2-2.5 and shove the clutch in while braking formidably my car will shut down. I currently am leaning towards the battery being the culprit here. Am I right? I was thinking about getting a deep cell marine type to see if that fixes it... I just recently had the clutch an flywheel replaced and was originally thinking it was due to the lighter flywheel. I think if anything that this UDP mod would worsen that effect? I have all belts now and I got the oil seal for the shaft too, is there anything else I should take into account, do, or purchase before I attempt this on monday? I am thinking about borrowing or buying a gear puller as well. THANKS ALL!!
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
Sep 27, 2015 08:37 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
