keyless entry module
Hey guys, anyone know where the keyless entry module is located?
Also does a gxe already have the wiring for keyless entry. In other words if i get a keyless entry module and a remote can i get it to work with my gxe?
No, it's not just like that.
Pop the trunk and remove the passaenger side trunk lining, the walls not floor. There should be a silver box. That's the brain but I don't think you have it anyway.
Try this: With all doors locked, put your key in and out of the ignition 6+ times in 10 secs. If your hazards flash, you should be able to use a keyless remote.
I thought the brain for the stock alarm was in the center console below the radio???
Originally Posted by DAVE Sz
The antenna is behind the wall the the brain is mounted on.
There are two connectors, one is to the antenna and one has a couple of wires in it, ie: power, ground, parking light flash, lock/unlock.
AaronL
Nov 15, 2020 11:52 AM
knight_yyz
Nov 1, 2015 01:34 PM
