Alignment specs on a 98 Max
Old May 11, 2001 | 05:38 PM
ionicmax's Avatar
Former Sponsor
Hello:
I would like to know what the alignement specs are for a 98 Max.
One other thing, how can I tell if my car is a Cali o fed spec?, My car doesn't come with the sticker under the hood. Can I find this some way in the VIN #?
Old May 11, 2001 | 06:46 PM
greenmax's Avatar
Originally posted by ionicmax
Hello:
toward the alignment there is no rear adjustment you can only set toe your total toe should be at 18 . that means 9 and 9 for left and rightside .
Old May 11, 2001 | 06:51 PM
Daniel B. Martin's Avatar
... I would like to know what the alignement specs are for a 98 Max. ...
This information is from the '99 Maxima factory service manual. I believe it also applies to your '98.
FRONT WHEEL ALIGNMENT
Camber, in degrees.
-1.00 Minimum
-0.25 Nominal
+0.50 Maximum
+0.75 Maximum left and right difference
caster, in degrees
+2.00 Minimum
+2.75 Nominal
+3.50 Maximum
Kingpin inclination, in degrees
+13.50 Minimum
+14.25 Nominal
+15.00 Maximum
Total toe-in distance, in millimeters
+1 Minimum
+2 Nominal
+3 Maximum
Total toe-in angle (left plus right), in degrees
+0.09 Minimum
+0.18 Nominal
+0.27 Maximum
REAR WHEEL ALIGNMENT
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
-3 Minimum
+1 Nominal
+5 Maximum
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
Old May 12, 2001 | 01:22 AM
ionicmax's Avatar
Former Sponsor
Thank you Daniel!!
Thank you very much, would you happen to know how to tell if my car is a cali o fed spec car? my car doesn't have the sticker under the hood.
Old May 12, 2001 | 09:49 AM
Destination
... would you happen to know how to tell if my car is a cali o fed spec car? my car doesn't have the sticker under the hood.
This information comes from the '99 Maxima factory service manual. I believe it also applies to your '98.
Raise your hood. Look for a shiny metal identification tag fastened to the
passenger side of firewall. The top row is the Vehicle Identification
Number, starting with J. The second row is model information. The first
five characters are BLHUL. The 12th character is the destination:
N = Canada
V = California
U = US, not California
matts95max
Apr 23, 2025 10:44 AM
NewMax03
Oct 29, 2015 07:44 PM
NewMax03
Oct 7, 2015 08:27 AM
Bonka
Sep 14, 2015 11:18 PM
