Daniel B here's some #s from Dealer
I went yesterday to my local Dealer to have them diag. the car and these are the results.
*SELF-DIAG RESULS*
FAILURE DETECTED TIME
KNOCK SENSOR 0
[P0325]
EGRC SOLENOID/V 0
these were already decoded
*FREEZE FRAME DATA*
P1400
FAILED PART
EGRC SOLENOID/V
=====SISTEM DATA=====
FUEL SYS-B1 # *no value here
FUEL SYS-B2 # **no value here
CAL/LD VALUE 0%
COOLANT TEMP 215C
S-FUEL TRM-B1 84%
L-FUEL TRM-B1 67%
S-FUEL TRM-B2 78%
L-FUEL TRM-B2 78%
ENGINE SPEED 662rpm
VEHICL SPEED 0km/h
*/** should be numbers here
And this is what they wrote:
MIL TECH FOUND RACING EMC INSTALLED IN VEH.-COMP. INFO GIVES HARD CODES FOR KNOCK SENSOR AN EGR SENSORS- OEM ECM HAS TO BE INSTALLED FOR REPAIR.
When i went back they told me about the racing ECU and that nothing can be fixed w/o the OEM ECU i just and told them i'll put it back before i'll come back. I also found out that there's 4 or 5 EGR sensors and that they have to know exactly witch one is failing in order to be replace and one of thech told me that they were out.
Now i'm trying to get a OEM ECU to install and fix any problems if there's any and send my ECU back to JWT to have check out.
JC
*SELF-DIAG RESULS*
KNOCK SENSOR 0
[P0325]
EGRC SOLENOID/V 0
*FREEZE FRAME DATA*
P1400
FAILED PART
EGRC SOLENOID/V
CAL/LD VALUE 0%
COOLANT TEMP 215C
S-FUEL TRM-B1 84%
L-FUEL TRM-B1 67%
S-FUEL TRM-B2 78%
L-FUEL TRM-B2 78%
ENGINE SPEED 662rpm
VEHICL SPEED 0km/h
JC
4 or 5 EGR sensors
Originally posted by JC
... I also found out that there's 4 or 5 EGR sensors and that they have to know exactly witch one is failing in order to be replace and one of thech told me that they were out.
