HELP!! my car wont downshift unless i floor it
Old Apr 28, 2005 | 09:34 PM
brownsvillemax's Avatar
can anyone help me? my car wont down shift unless i floor it to the metal. that cant be right. also, once it does manage to down shift, i can feel the powerband switching around like if the timing is adjusting or something. i have an injen intake ws superflow y pipe and magnaflow high flow cat with stock catback for now. any advice ????
Old Apr 28, 2005 | 09:36 PM
izzydig's Avatar
Floor it alot? Then maybe seek a new/used tranny.
Or check the fluid.
Old Apr 28, 2005 | 10:01 PM
the trans. fluid is clean and in good condition and they are at the level they should be... could this be a tps, maf or knock sensor problem?
Old Apr 28, 2005 | 11:14 PM
izzydig's Avatar
The only time I have trouble downshifting in an auto, is when flooring from 50-60+. It tends to goto 2nd from 3rd, which is not good. I usually let up at that point, leading the tranny to search for the correct gear based on my foot-input. :P If from a straight-line accel, it shifts normally...1.2.3.
I dunno...bump.
Old Apr 29, 2005 | 04:40 AM
njmaxseltd's Avatar
You have a 99, the power surge your feeling at WOT is most likely a failing coil. That might be causing your tranny to act funny too.
Old Apr 29, 2005 | 09:17 AM
maxiquin's Avatar
damn a bra ona max! take dat ish off! this aint the 90's
Old Apr 29, 2005 | 10:28 AM
98MaXeDouT's Avatar
*sigh* ...
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
erniel
Aug 8, 2015 09:32 AM
