0210 code
Old May 1, 2005 | 01:06 PM
_maxxedout_'s Avatar
0210 code
I pulled this code recently and I am wondering if anyone has had this before and what they did to fix it. I don't need anyone pulling the stickies out; I've read them. I also did the hacked air box mod and don't know if that is what is affecting it. Thanks for the imput!
Old May 1, 2005 | 01:22 PM
Kevlo911's Avatar
Kevlo for President
Well one of the causes is an intake system leak. You check for any leaks?
Old May 1, 2005 | 01:27 PM
yes I have checked for leaks and none have been found.
Old May 1, 2005 | 01:29 PM
Kevlo911's Avatar
Kevlo for President
Reset ECU and see if it comes back.
Old May 1, 2005 | 06:51 PM
done that as well and it has come back twice
Old May 1, 2005 | 07:10 PM
KsuMax's Avatar
Cheesing away...
0210
Diagnostic Trouble Code 0210 points to a problem with the fuel injection system. When the engine management system is running in closed-loop mode the Engine Control Unit (the computer) makes continual adjustments to maintain the air-fuel ratio near the ideal point. To achieve this it relies on signals from many sensors including the Mass Air Flow Sensor and the Oxygen Sensors.
This malfunction is detected when the ECM finds that it cannot properly control the air/fuel mixture, and the mixture is too lean (too much air). DTC 0210 indicates this problem exists on the left bank (the front bank, cylinders 2, 4, and 6). Possible causes include ...
- Intake air leaks
- Front Oxygen Sensor
- one or more fuel injectors on the front bank
- exhaust gas leaks
- incorrect fuel pressure
- lack of fuel
- Mass Air Flow Sensor
Old May 2, 2005 | 12:36 PM
Ksu if you took the time to read the top of the thread...........you would have seen the sentance "I don't need anyone pulling the stickies out; I've read them." Anyways thank you for the effort of helping. Oh and the original purpose of me checking BuMp....
Old May 2, 2005 | 06:18 PM
bump........
Old May 2, 2005 | 07:40 PM
KsuMax's Avatar
Cheesing away...
I know, but I was saying what could have set it off, check those and see if o2 sensors, plugs are all working and screwed in tight. Also check to see if your gas cap is on tight, if it's been loose for a while, a cel code has been known to show up
Old May 2, 2005 | 08:09 PM
gas cap!?!?! really never heard that one before interesting.........
Old May 3, 2005 | 05:59 PM
for the love of BUMP>>>>>>>>>
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
