brakes clicking??
Old May 2, 2005 | 07:18 AM
ruffrida24444
brakes clicking??
hey guys i installed my rims a few weeks ago and i guess since their so open i hear a clicking noise coming from my calipers now. after driving for a while it usually goes away but its annoying and idk wut it is. thanks guys.
Old May 2, 2005 | 07:17 PM
ruffrida24444
help.................................
Old May 3, 2005 | 07:44 AM
ruffrida24444
Old May 3, 2005 | 07:56 AM
MrEous's Avatar
^ Jeff™
Sooo...it's clicking.
Is it just 1 wheel? Is it only when you're turning? Is it only when brakes are applied? We need more info.
Old May 3, 2005 | 10:51 AM
JPMax's Avatar
What's next!?..
Check your CV joints/boots if the noise is coming from the front wheels.
Old May 3, 2005 | 11:38 AM
MrEous's Avatar
^ Jeff™
...also make sure you don't have a rock/nail/screw in your tire.
Old May 3, 2005 | 01:37 PM
alpimax99's Avatar
did my brakes a few weeks ago mine are clicking. i tried differant pads same problem. haven't figured out why yet.... Also installed cross drilled and slotted rotors but all the slots a smooth no sharp edges. it is puzzling to me
Old May 3, 2005 | 04:59 PM
ruffrida24444
prety sure its all 4 wheels. sounds like more of a metal clicking. no nails or rocks in tires. it goes away when i'm braking and its make'n me go nuts...
Old May 3, 2005 | 05:28 PM
JPMax's Avatar
What's next!?..
pretty rare that all 4 wheels would make noise at the same time.
What size rim and offset did you put on? Did you work on the brakes at all recently?
Old May 3, 2005 | 06:53 PM
ruffrida24444
no work on the brakes recently. i had my rims on last yr but didnt have this problem. but i recently added s techs and kybs but i doubt this would have anythign to do with it. i'm confused as to why it goes away after driving for 5 min and doing some braking, even at the same speed.
....this blows
Old May 3, 2005 | 07:57 PM
the_3d_man's Avatar
...Take off all of the brake pads and look for any unusual wear. Make sure nothing got between the rotor and the hub. Make sure nothing got between the rim and the rotor. Make sure nothing got between the Brake pad and the rotor. Do that to each wheel. Also ... make sure you tightened down all of the lugs cause if you didn't that will make bad noises (and evetually worse... as in wheel falling off). Also it is possible that the pads are rattling around in their seats. Try putting some of that anti squeal grease between the pads and the calipers. It works.
Old May 4, 2005 | 05:00 AM
JPMax's Avatar
What's next!?..
I think you should contact njmaxseltd (aka Tom). He has a shop up in Garfield. (about 30min from your location.)
I'm sure he'll take a look at it for you this weekend if you want.
Old May 4, 2005 | 07:05 AM
ruffrida24444
thanks guys i dotn think its major. i think the pads are rattling in their seats. that sounds exactly what it might be...
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
