Strange sounds, Trans?
Old May 3, 2005 | 10:26 AM
nismos14's Avatar
§è~® f®ÈÄk
When I am not in gear and off the clutch I get a strange kind of hissing sound. If I put the clutch down ALL the way, it goes away, as soon as I bring the clutch back up about an inch or two it makes the hiss sound again. I believe it does it in gear as well. Does anyone have any idea what this could be? car runs fine, clutch does not slip at all.
Old May 3, 2005 | 11:15 AM
dayglo's Avatar
i think i might have something like this as well
when the car is cold mainly, it sounds a bit like a grind but when i put the clutch in you can hear the noise stop as it slows spinning. its pretty quiet though and you couldnt notice it over anything else unless you obsess about the noises your car makes, like us.
i wonder what it is too
Old May 3, 2005 | 12:36 PM
nismos14's Avatar
§è~® f®ÈÄk
wether my car is in gear or not, has no affect on this sound as far as i can tell. and it happens whether the car is cold or warm
Old May 3, 2005 | 01:14 PM
PAREDLINE's Avatar
Sounds like you have a bad throwout bearing
Old May 3, 2005 | 01:37 PM
nismos14's Avatar
§è~® f®ÈÄk
can it just go bad out of the blue or over time? and they have to drop the trans to repair it don't they?
Old May 3, 2005 | 01:55 PM
thekenone's Avatar
i doubt its the thowout bearing. i have the same problem and i just replaced my cluch and thowout bearing. didn't fix the noise. it has been suggested to me that is the input shaft bearing. either way the tranny does need to be dropped. its not that hard acutally un less you aare like me and have a rusty underbody. mad the bolts hard.
Old May 3, 2005 | 03:36 PM
nismos14's Avatar
§è~® f®ÈÄk
so if its the input shaft bearing, do i need to get it done asap, or what?
Old May 3, 2005 | 03:45 PM
oVeRdOsE's Avatar
Thanks to open this thread, ive my max since 2 weeks , and TODAY my manual trans start to hissing!! I dont understand, and when im on the neutral and I press the clutch, the funny sound appear ...
And when im riding, and i arrive to a stop, ofcurse i downshift and i ear a noise, like a compression sound, and its not the engine.
Some people says thats a bearing...
Somebody knows??
Old May 4, 2005 | 10:53 AM
oVeRdOsE's Avatar
Tp tHe ToP ......
Old May 9, 2005 | 08:18 PM
G20Flyer's Avatar
Mine does the same...I know its a mainshaft bearing...we have the lovely shim problem. Don't know if I want to drop $1500 in a new clutch, pp, bearings and rebuilt tranny lol
Old May 9, 2005 | 08:24 PM
CleanMAX98's Avatar
its the bearing just got mine fixed
Old May 9, 2005 | 08:32 PM
G20Flyer's Avatar
Which bearing bro??
Old May 9, 2005 | 08:41 PM
CleanMAX98's Avatar
throwout bearing
Old May 10, 2005 | 04:58 PM
jome80627's Avatar
I had the same noise. Eventually, the noise got louder and louder and became very difficult to shift at times. I ended up having to drop about 1200 for a trans. rebuild. Hopefully it holds up. It feels great now that it's fixed though
Old May 10, 2005 | 07:06 PM
nismos14's Avatar
§è~® f®ÈÄk
no i dont have a shim problem my trans was dropped and looked at already, and it doesn do it when the car is in gear, only when its not in gear
Mahmuth
Aug 16, 2024 08:23 PM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
ef9
Oct 4, 2015 08:43 AM
