Replaced o2 sensor still getting codes
Old May 3, 2005 | 12:56 PM
nismos14's Avatar
§è~® f®ÈÄk
Well today i replaced my o2 sensor, i was getting 0303 and 0707. i replaced the front o2, and got a cel again, and it was 0707 + 1001. WTF! front left heated o2. I know the rear o2 cel is coming up bc of my g-force ecu, at least i think it is, it may also be time to change it anyways, but why did i get the 1001 for the front left heated o2 again??
Old May 3, 2005 | 01:19 PM
MrEous's Avatar
^ Jeff™
Are you sure nothing is wrong with your ecu? Just asking.
Old May 3, 2005 | 01:30 PM
MDeezy's Avatar
maybe the reason behind your G-force ecu cause the rear o2 to pop up as a cel is doing the same for your front o2. Just an idea.
Old May 3, 2005 | 01:37 PM
nismos14's Avatar
§è~® f®ÈÄk
i'm sure nothings wrong with it, the power is great but idk about the rest.
Old May 3, 2005 | 01:40 PM
Mishmosh's Avatar
Which front did you replace?
I would get to the bottom of this. Your fuel mileage can suffer. Power at WOT (open loop) will not be affected but it would bother me to know the car is not in tune.
Old May 3, 2005 | 02:29 PM
Loe max's Avatar
Did you use a Universal O2 sensor or an OEM O2 sensor?
Old May 3, 2005 | 03:35 PM
nismos14's Avatar
§è~® f®ÈÄk
I replaced the one all the way towards the front of the car on the left side when you're facing the trunk. Universal wagner o2 but it had the oem connector on it and three wires, and all throughout the time i've had the code i've gotten 28-32 mpg.
Old May 3, 2005 | 04:38 PM
Loe max's Avatar
Reset the ECU or swap the two white wires.
Old May 3, 2005 | 07:25 PM
nismos14's Avatar
§è~® f®ÈÄk
i reset it and got just the 0707 that i had been getting, gonna replace the rear o2 eventually and see if my problem persists.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
