Front Strut Bar
Old May 3, 2005 | 06:06 PM
MystA RavE's Avatar
Front Strut Bar
Does it make sense to put on a front strut bar from Ebay if thats the only thing i'm going to put on(no rear strut).
Old May 3, 2005 | 06:18 PM
KNYFE's Avatar
In very aggressive driving it would make some difference. For the most part they are cosmetic.
Old May 3, 2005 | 06:19 PM
ti2tmax's Avatar
Has his VINs memorized
FSTB is a FSTB. I have an ebay special and it works (almost) as good as a more expensive one. I think Stillen should be excluded from that list though... You don't really feel much of a difference with a RSTB unless you are a hard core cornerer.
Old May 3, 2005 | 06:28 PM
KNYFE's Avatar
The rear is very noticable if you have the rear sway. But for everyday driving... None of them really do much.
Old May 3, 2005 | 07:15 PM
95VQ30's Avatar
There was a very noticable difference from my car, cut front body roll in half. They are not just cosmetic....
Old May 3, 2005 | 07:17 PM
nosispower's Avatar
A front strut bar wouldn't cut body roll at all...
I think it was mostly in your head. I got my bar and I can say that my steering seems a tad more responsive in tight corners and maybe there's a little more effort but nothing immediately noticeable.
Old May 3, 2005 | 07:30 PM
ti2tmax's Avatar
I must say, so far I have felt very minor results with RSTB, but felt fairly modest results with the FSTB. I can't wait to get an RSB. And granted you get what you pay for...
Old May 3, 2005 | 07:38 PM
MystA RavE's Avatar
Yeah...I figured that something that costs only around $20 would be pretty much useless
Old May 3, 2005 | 07:41 PM
ti2tmax's Avatar
I've heard Stillen is the best FSTB because it allows you to actually preload your front suspension. That's just going on "hear->say" though. but I think it's cattman who sells a combo of FSTB and RSB which are a decent combination upgrade to your suspension.
Old May 3, 2005 | 07:44 PM
KNYFE's Avatar
I have Stillen in front and back and can tell a little difference in aggressive driving compared to the old fstb.
Old May 3, 2005 | 07:47 PM
2 Da Max's Avatar
what about on sharp turns with the fstb?
Old May 3, 2005 | 07:49 PM
killerVQ30DE's Avatar
Its $20 buy it anyway seriously if I could pick up performance car parts in this country for $20 I'd be thrilled beyond belief
Old May 3, 2005 | 08:21 PM
Doc's Avatar
Doc
It will make some modest difference. Can't hurt.
Old May 3, 2005 | 08:47 PM
97BlackSEGold's Avatar
I had an ebay one in my camaro and it made a slight, but noticable difference. But that also had a real stiff suspension. I would think it would make more of a difference in a maxima.
Old May 3, 2005 | 08:54 PM
MystA RavE's Avatar
Thats why I asked the question...if its worth me paying $20, and then having to install it by somehow getting off rusty bolts with a lot of force. If this is for nothing, then it doesnt matter how much it costs.
Old May 3, 2005 | 11:45 PM
ImmaSquashYou's Avatar
its like this, when you do something, do it right the first time. the ones on e-bay for 20 bucks are basically useless. its useless because the joints aren't strong enough to make a difference in turning ability. the bolts will most likely move when the strut bar is in need of use. i mean 20 bucks is 20 bucks. i'd rather get a used one from someone knowing that it will perform a lot better. rusty bolts aren't really anything if you got some wd-40 and a torque bar. Hence, i'm still trying to get one that doesn't use bolts but welded straight across like my bro has on his rsx. i personally think that putting a cheap mod into the suspension is asking for trouble. You might probably think that you CAN turn faster and take a turn too fast for your own good since you THINK
you do have a mod.
Old May 3, 2005 | 11:54 PM
Dragon's Avatar
I just ordered the suspension package from Cattman, Front Strut Br and RSB, Titanium. Ill keep you posted when I install them.
Old May 3, 2005 | 11:58 PM
egxflash's Avatar
how much did that run you dragon?
Old May 4, 2005 | 12:16 AM
MystA RavE's Avatar
It would be good if you installed the front first, drove around a little bit and then installed the rear. You can then tell if the front strut is doing anything without a rear. If you decide to do this..post your results. If not, just post your results after the whole kit is installed.
Old May 4, 2005 | 12:51 AM
Maximus_95's Avatar
you will be paying $20 dollars just for better engine bay fuller look, it wont make a difference, the only difference you can actually tell is with a rear sway bar, now that's a big difference!
Old May 4, 2005 | 02:24 AM
garbury's Avatar
you do have a mod.
No, it's not like that. Those Ebay bars work beautifully. All they do is brace the two strut towers so they don't move, and you don't need some "titanium welded bracket" bar to have good performance from them. I've got one ebay bar on each maxima and the difference is amazing. Even with a fsb, rsb, tokicos/eibachs and then adding the fstb, my handling was very dramatically improved. Hence they are 3rd gens, but don't underestimate the ebay fstb.
Old May 4, 2005 | 04:39 AM
2 Da Max's Avatar
they all do the same shiet. but there not really that effective on our cars. we have more body roll in the back which needs to be tightened up
lowpost99
Oct 26, 2025 06:53 PM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
