Power Seat Swap Problems?
Old May 3, 2005 | 06:50 PM
baughb's Avatar
Anyone have problems when going from factory cloth to power (non heated) leather? It all plugged in properly, but wont move. Is there a fuse/relay im missing?
Old May 3, 2005 | 07:13 PM
ThisMaxIsTight's Avatar
i did the front seat swap...those plugs that connect to each other are really tuff to push together...make sure they SNAP into place...and make sure you have the right plugs in the right holes ... should work
Old May 3, 2005 | 07:41 PM
baughb's Avatar
should..... still no dice. I can move them all manualy (with a battery), so I know its not the motors, maybe the damned relay box thing next to the seat
Old May 3, 2005 | 08:00 PM
Ceasars Chariot's Avatar
Old Maxima Legend
hmm, i swapped some 96 leather to replace my 97 leathers and had the same problem at first, rechecked and had to snap the power in good as well
Old May 3, 2005 | 08:29 PM
baughb's Avatar
just the two plugs under the seat right??? =(
Old May 3, 2005 | 09:31 PM
baughb's Avatar
anyone have the interior wiring diagram? I dont have any power to the seat plug
Old May 4, 2005 | 06:56 PM
baughb's Avatar
bumpidy bump
Checked all fuses, rechecked connections
if I put power to the seat relay using a jump box, it all functions. Is there a connection/something Im missing?
Old Oct 28, 2008 | 09:34 PM
maxkid123's Avatar
i have the same problem dude i cant figure it out to save my life...
Old Oct 29, 2008 | 04:33 AM
njmaxseltd's Avatar
Did you check for power at the plug with a meter?
Old Oct 29, 2008 | 05:57 AM
MikeB's Avatar
It worked for me '99 seats into '98. I agree meter it out ck for power, ground is good. Heated portion I believe is separate plug which I don't have, but my Max is going to stay out of the cold this winter I hope.
Old Oct 29, 2008 | 06:17 AM
KRRZ350's Avatar
Originally Posted by baughb
bumpidy bump
The power wire on the low power side of that relay? My geuss is it runs through a key-on fuse that wasn't installed from the factory.
Old Oct 29, 2008 | 07:02 AM
pmohr's Avatar
No more Maximas...
There's a circuit breaker for the factory power seats that indeed isn't installed in cars that weren't equipped with power seats.
Actually, this just came up the other day - http://forums.maxima.org/4th-generat...her-seats.html
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
1992maximase30
Aug 5, 2015 09:27 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
