I thynk i need a new engine where can i get 1???
Old May 5, 2005 | 03:20 PM
97maxxx's Avatar
just like the title says -where can i get a new engone becuase now i have a bad oil leak and im even leaking antifreeze from somewhere and its not the radiator??????please help me and yea i live on long island so if it could the closer the better
Old May 5, 2005 | 03:22 PM
97maxxx's Avatar
o yea and how much do you thynk it will cost to get installed? well the whole project including the install and does anyone do good installs on the island
Old May 5, 2005 | 03:26 PM
Bobo's Avatar
So you could have a problem with your oil sensor, or your oil filter isn't tightened properly, and you may need a new water pump or hose! Who knows? I suggest you get your problem diagnosed first and quit running around saying "the sky is falling."
Old May 5, 2005 | 03:40 PM
MaximaSE96's Avatar
Maxima Owner
wo wo wo lets back the maxima train up....lke murdoch said y dont u have a professional or an ORGER in ur area look at it before u think u need a new motor....it could be many things that cost WAYYYYYYYY less then a motor swap......
Old May 5, 2005 | 04:49 PM
97maxxx's Avatar
well i cant drive it anywhere -i dunno ive been thinkin bout it and i atleast need a rebuild -def valve cover gaskets and an anti freeze line somewhere-it also jumps all over the rpm band and even pops into gear now -all of this after trying to install new valve cover gaskets
Old May 5, 2005 | 07:08 PM
speed racer's Avatar
You could spend a little less than a G. to rebuild your engine. I would imagine that's easier than buying an engine around 600 - 800 than having it getting it installed. Go to Shea Stadium though and look over there at the Junk Yards I'm sure you can get some answers.
Old May 5, 2005 | 08:01 PM
ThisMaxIsTight's Avatar
DUDE...r u serious??...a new motor is highly unlikely...call up a towing company and have it towed to a TRUSTY mechanic and have them DIAGNOSE your problem...who the heck has a problem and starts babbling about a bad motor????
Old May 5, 2005 | 09:10 PM
MDeezy's Avatar
Wow everyone is kinda attacking him, he's a little freaked out cause his engine seems like its about to die out on him.
like stated have your engine checked out, preferable have a knowlegable org member meet you and check it out with you (offer them some beer or some food), coolant leak good chance is the water pump which is a task to ge to but a cheaper one than a new engine. post back with your findings.
Old May 6, 2005 | 05:11 AM
tedo007's Avatar
faster than you think
www.ebay.com or www.car-part.com
Old May 6, 2005 | 05:40 AM
Iron Scimitar's Avatar
Tha Snatcher
i thynk you need a quality technician to look @ your engine. A new engine is highly unlikely just as everyone else had stated.
Old May 6, 2005 | 06:08 AM
shavedmax's Avatar
no one caught this? obviously if the car was running fine prior to your replacing valve cover gaskets, so you screwed something up. if its leaking oil, dontcha think it may be comming from say...................... the valve cover gaskets? im pretty sure you have to remove the intake to do valve gaskets, so you probably have a vacuum leak from that (making the car run like crap)and the coolant leak is from that also(coolant usually flows through the intake). take it to a mechaninc and have him/her fix it properly. end of story
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
