Front Corner Lights light up when I step on the brakes!
Old May 7, 2005 | 09:27 AM
BlackCat's Avatar
RIP '98 Maxima SE
I noticed this week that when I press on the brake pedal my front clear corner lights light up as well! Any ideas where the wires may have crossed?
I did the fog light mod last summer and that went well. Opened up the relay box to see if any wiring was loose but it looks fine.
Old May 7, 2005 | 10:09 AM
MAXRB8's Avatar
Hey cool new mod!
Oh you didn't mean for it to be that way? That's a tough one, anybody?
Old May 7, 2005 | 01:16 PM
BlackCat's Avatar
RIP '98 Maxima SE
My Fuse #5 keeps blowing. Crud! Looks like I may have to restore the fog light connections back to the original setup.
Old May 7, 2005 | 01:30 PM
RA030726's Avatar
I'm nutty for Nissans
thats weird. do the rear blinkers do the same? do the blinkers illuminate the brake lights?
Old May 7, 2005 | 01:43 PM
JOMAN's Avatar
ouch...cool mod! LOL ummm maybe try using a higher wattage for the fuse...but about fixing ur problem..i have no clue..sorry.
Old May 7, 2005 | 01:54 PM
Kevlo911's Avatar
Kevlo for President
I think you tapped the wrong wire...
Old May 7, 2005 | 03:24 PM
BlackCat's Avatar
RIP '98 Maxima SE
I followed that fog light rewire write-up to a T and it worked fine. Remember, I did this last summer.
Old May 7, 2005 | 03:28 PM
MAXRB8's Avatar
If you're blowing fuses you've obviously got a short, can you disconnect the fogs completely, then try a new fuse
Old May 7, 2005 | 05:30 PM
BlackCat's Avatar
RIP '98 Maxima SE
Ok, I've disconnected the wiring from the fog light relay that splices into the corner light, soldered the connections and wrapped them in electrical tape. When I turned on the lights the clearance lights next to the headlights did not light as well as the corner lights in the taillights. I checked the 7.5A fuse and it blew again. Popped in another and it too blew. This time I put in a 10A and that worked.
Now that didn't clear up the problem with the clear corner lights lighting up with the stoplights when I pressed on the brakes. Also I didn't notice that my dash light around the speedo as well as the lights for the boost gauge, fuel pressure gauge and EGR gauge now lights up when I pressed on the brakes.
I turn the lights on by going to the first notch on the headlight stalk in lieu of the daytime running lights because of the heavy duty headlight harness. Since I'm not knowledgable when it comes to electrial stuff I'm guessing that the line may have gotten too hot and that it may have melted the insulation somewhere? Is this possible and has anyone else who's done this mod experienced this problem before?
Old May 7, 2005 | 05:43 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
you have a cross short.
Old May 7, 2005 | 05:52 PM
MAXRB8's Avatar
I'm guessing you have meted a couple of wires together also and putting in a 10amp fuse will only allow more current causing more heat!!!! and quite possibly more damage! Time to take it to a pro!
Old May 7, 2005 | 08:34 PM
RA030726's Avatar
id look at the wiring for the tail lights and brake switch... heck any thing in between. use a multi meter and test light to check the ciruits.
Old May 7, 2005 | 08:52 PM
joooowan
lol you should get your friend's car, and wire the horn to the brakes.
Old May 8, 2005 | 08:02 AM
BlackCat's Avatar
RIP '98 Maxima SE
Wow! Is that what you did??? Please do the write-up for that mod and post it in the stickies section!
Well that fog light mod sure bites the big one now. That write-up should be stricken from the stickies.
Old May 8, 2005 | 08:05 AM
BlackCat's Avatar
RIP '98 Maxima SE
I'm not familiar with a multimeter so it looks like I'll have to take it into the stealership, pull my pants down and bend over.
At this point, when I step on the brakes the door-open chime kicks in. Definitely a cross-short.
vingodine
45
May 21, 2016 12:46 PM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
Samedi
Aug 13, 2015 04:05 PM
