what size speakers do i have?
Old May 7, 2005 | 11:24 AM
jarrod91se's Avatar
just got my 98 max se. it didnt come with the bose system so i dont know what size speakers are in the front or the back. i went to crutchfield.com and put in my cars year...etc. they came up with 6.5, 6.75, and 5.25 for the front AND the back. now how is this possible?
Old May 7, 2005 | 11:48 AM
sook's Avatar
fairly certain theyre all 6.75, but someone smarter'n me is sure to sound off
Old May 7, 2005 | 03:08 PM
adampecush's Avatar
6.5 all around.
Old May 7, 2005 | 04:09 PM
jaemax's Avatar
even if it is BOSE? I took apart the deck not knowing the size and took my 6x9's out my 3rg gen to improve the sound and WHAM!!!!!! these did not fit... i was tight... to take apart that deck is quite the obstacle... and then to find out that they dont fit... can you say FUSTRATION!!!!! anyhow... if they are 6.5 not bad I guess... will aftermarkets fit and connect to the BOSE amps???
Old May 7, 2005 | 06:18 PM
PBX's Avatar
PBX
6 3/4 front and back
Old May 7, 2005 | 08:06 PM
jarrod91se's Avatar
ok now which one here.....6.5 or 6.75?????????
Old May 7, 2005 | 08:09 PM
BuNGsVQ's Avatar
6.5's fit from what I know. 6.75's are the size that are on there.
Old May 7, 2005 | 08:10 PM
monty95's Avatar
Im pretty sure its 6.5...Thats what ive seen whenever ive looked them up....those places might be wrong.... you should have asked this question in the Audio forums, but its all good i guess....go with 6.5.
Old May 7, 2005 | 09:00 PM
Amarao's Avatar
BOSE system is 1 ohm, most others are 2 ohm or higher, so you have to replace everything or buy the expensive BOSE parts, i blew 2 amps on my bose and just went for a new deck and infinity speakers.
Old May 7, 2005 | 09:24 PM
jaemax's Avatar
what do you mean, "went with a new deck"? I want to replace the BOSE speakers on my deck and doors.... where do I begin? what are the best speakers to put.. with possibly, utilizing the BOSE amps for the time being...
Old May 7, 2005 | 09:51 PM
Amarao's Avatar
your bose amps are mounted directly to your speakers, and they have a 1 ohm resistance, there is NO deck or speakers with that resistance unless you get bose. I looked all over and can't find any speakers or decks lower than 2 ohm, so you either stick with all bose or get something different and the speakers are 6.5" fyi
Old May 8, 2005 | 06:06 AM
dukelubas's Avatar
Org Lurker
6.5" will work because they have the slotted holes to allow for a larger diameter pattern but the real size is 6.75". I know, I just did the research and just replaced mine.
Old May 8, 2005 | 06:28 AM
mansurxk's Avatar
6.75", but you can definatley buy 6.5"
Old May 8, 2005 | 12:28 PM
96SEMaxima's Avatar
My se didn't have the bose. When I pulled them out and measured them they were 6.5".
I recommend 6.5" infinity kappa's front and back. That's what I used.
Old May 8, 2005 | 12:30 PM
maximaintheface's Avatar
I Use 6.5" Speakers Front And Back
Old May 8, 2005 | 12:34 PM
88FordFestiva's Avatar
6.5", 6.75" and 7" are usually interchangeable without adapters, which is why different places might tell you different things. However, the best fitting size and the intended size is 6.75". Most speakers that say 7" are actually really 6.75". For example, http://www.cardomain.com/item/PIOTSA1780R?vq_id=none
Old May 8, 2005 | 01:20 PM
PandaXpress's Avatar
6X9's in the back and 6.5 double compnent kove audio speakers
Old May 8, 2005 | 05:04 PM
FormorAccordMan's Avatar
To jaemax-Elemenatal Designs 6500's -best set you aregonna find in the sub $350 catagory. WELL WORTH IT. Ditch the rears, and get a sub and good front stage and call it a day. The bose is class A garbage. Bose is a company that sells crap to those who don't know anybetter. People see BOSE and go "OOOOOOH BOOOOSE." Many people unfortunately have never heard true high fidelity and don't know what they are missing. They think that BOSE is a Hifi comapny. There are TONS of other companies out there that wipe the floor with BOSE, Both for Home and car audio especially for the price. Now If only magnepan sold speakers for car audio........
Old May 8, 2005 | 05:15 PM
Originally Posted by FormorAccordMan
To jaemax-Elemenatal Designs 6500's -best set you aregonna find in the sub $350 catagory. WELL WORTH IT. Ditch the rears, and get a sub and good front stage and call it a day. The bose is class A garbage. Bose is a company that sells crap to those who don't know anybetter. People see BOSE and go "OOOOOOH BOOOOSE." Many people unfortunately have never heard true high fidelity and don't know what they are missing. They think that BOSE is a Hifi comapny. There are TONS of other companies out there that wipe the floor with BOSE, Both for Home and car audio. If only magnepan sold speakers for car audio........
I agree absolutely 100%. Everybody has a budget, some can't afford great speakers, but in no case is BOSE efficient money-wise.
Old May 8, 2005 | 07:59 PM
jarrod91se's Avatar
on a 4th gen without Bose whats the highest depth # you can go without causing any problems...windows...etc.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
