removing the headlights
i have a 95 maxima and i am changing the headlights and the grille to the 97-99 type. the only problem is on the left side i cant get the one bolt off because there is a pipe in the way. so i need some help.
thanks
thanks
The Haynes manual says to take the radiator out to replace the headlamps... but I got around that easily enough...
Just use a socket extension that's thin enough to get past the pipe with a good angle, and you should be able to get to it just fine. When screwing the nut back in, start it with your hand so it threads correctly, tighten with said socket+extension.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
