Replacing GXE Dash Gauge Cluster with SE DGC
Old May 10, 2005 | 06:38 PM
Wheelie King's Avatar
I am considering replacing my 97 dash gauge cluster (speedo, tach, fuel, temp) with the white faced cluster from a 98 SE. Has anyone done it? Did you run into any problems?
Thanks.
Old May 11, 2005 | 07:37 AM
BLaKtOut's Avatar
ya i wana do this cant find them though hard to find
Old May 11, 2005 | 08:17 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
good luck. 98 is digital. so different holes for the odo.
Old May 11, 2005 | 09:35 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
+ you would need to match the SE cluster w/ your current mileage .. I've seen ppl use some sort of machine to do this
Old May 11, 2005 | 09:36 AM
johnny1285's Avatar
The fuel gauge is a little different too, the 98 fuel gauge is mirrored to the temp gauge, which means the gauge faces the other way. I dont know if that would effect you from swaping it.
Old May 11, 2005 | 09:41 AM
tedo007's Avatar
faster than you think
i like the 95, and 96 SE white gauges and needles better
Old May 11, 2005 | 06:21 PM
Are the 95 and 96 gauge clusters compatible with a 97?
If the 98 is not compatible with a 97 then I won't bother with the one I found. Maybe its a 97. I'll check again. If anyone is interested then let me know. I found this one already removed in the back seat of a car in a local junk yard. If you want it then let me know. I'll find out what they want for it and let you know. I assume it isn't broken. I don't know how to check the internal mechanisms though. It looked from the outside though. I saw several others that would need to be removed. Anyone interested let me know. I can at least give you the name and number for the yard.
Old May 11, 2005 | 06:58 PM
the '98 will work, just that the cluster is wired diff. .. there have been some ppl who have installed '98 clusters, forgot who did it
Old May 12, 2005 | 05:56 AM
killcrap's Avatar
a 95 will work fine in your case. all 95-97 are the same cluster, just different needles. and gauge overlays.
Old May 12, 2005 | 10:08 AM
lilaclucymaxima's Avatar
Team Ramrod
I did a similar swap. I changed my black GLE gauge faces from my '95 with my friend's old white SE gauges from his '96. I just changed the faces though. I would have changed the miles myself, but his had over 131,000 miles and I only have 84,300. If you swapped the entire cluster there shouldn't be any problems.
Slamrod
Apr 10, 2016 05:24 PM
Ray229Harris
Sep 16, 2015 08:16 PM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 13, 2015 12:50 AM
Trin1j23
Aug 12, 2015 08:31 PM
