car pull right done alighment twice
Old May 11, 2005 | 10:11 AM
lshi0's Avatar
hello all, i just got 2 new front tires, and car started to pull right, i have done alignment twice. Autoshop being very helpful, did second alignment for free. Any advice? thanks!
Old May 11, 2005 | 10:50 AM
njmaxseltd's Avatar
Could be radial pull. Swap the left and right tires and see if the pull follows the tires.
If you have the print out of the alignment specs, please post them.
Old May 11, 2005 | 11:24 AM
ravrunner's Avatar
Alignment
Hey, I have a similiar problem but my max goes to the left and i got my alignment only 4 months ago. It vibrates a little after a certain speed too, any ideas on what I should check? I know I have to check my calipers and rotors.
Thanks for the info guys.
Old May 11, 2005 | 01:05 PM
BK1's Avatar
BK1
Hello
Was the car previously in an accident? Bent frame?
Old May 11, 2005 | 02:06 PM
lshi0's Avatar
yeah, but only door , fender and bumper. No damage to frame.
Old May 11, 2005 | 02:10 PM
lshi0's Avatar
here are the alignment report
Front
Caster
Left 2.5
Right 3.2
camber
Left 0.1
right -0.3
Toe
left 0.1
right 0.1
Total 0.2
Rear
Camber
Left -0.1
Right -1.3
Toe
Left 0.1
Right0.05
Total 0.15
i30ds's Avatar
Armed and Dangerous
Is it doing it only during braking? If so, it could be bent rotors or rusted caliper slider bolts...
Old May 11, 2005 | 02:13 PM
lshi0's Avatar
nah, i have to keep steering wheel slightly left to keep vehicle straight, otherwise it drifts to right.
Old May 11, 2005 | 02:32 PM
DragonMaxima's Avatar
Related Problem:
My steering wheel is turned slightly to the right when I go straight. I would say if the center is 12:00 My wheel is pointing to 1:00 when I want to go straight.
Is there a specific problem or do I just need an alignment?
BTW: I had an alignment done as well and it didn't fix it. This was 2months ago.
Thanks.
Old May 11, 2005 | 03:17 PM
Jatan's Avatar
I have a "pull" problem and the guy at the body shop I went to for an estimate said that my driver side outer and inner tie rods need replacing...
Old May 11, 2005 | 03:47 PM
BigLou93SE's Avatar
Yup, I have that problem.
Old May 11, 2005 | 04:12 PM
killerVQ30DE's Avatar
Yeah its most likely your tie rods, or lower control arm ball joints
Old May 11, 2005 | 06:54 PM
PTownMax's Avatar
I still miss the max
check tire pressure it could be something as simple as the shop doing not enough or too much air. just a thought since tires r new
Old May 11, 2005 | 06:56 PM
Jatan's Avatar
For me it's the tie rods, but I thing frozen/sticking calipers could also cause a drag/pull to one side
Old May 11, 2005 | 08:26 PM
HomerMAC's Avatar
Donating i30 Owner
well my call pulls too.. but the funny thing is when i turn the steering.. at a stand still i hear ... clanking.. and ding.. type sounds.. its weird.. and i had it on a lift and everything seemed okay..? suggestions.. did u guys use any particualr strut mounts after drops.. and any particualr alignment settings..?
Old May 12, 2005 | 02:11 AM
lshi0's Avatar
are wheels gonna get loosed over time if i dont get it fixed soon?
Old May 12, 2005 | 03:00 AM
96ItaliaSE's Avatar
il massimi bassi
you can score inner and outer rod ends and new control arms and sway links for under 250$. MY steering wheel is now centered but i still have a pull to the right
Old May 12, 2005 | 03:43 AM
dgeesaman's Avatar
Maintenance Monster
Are you sure the steering wheel simply isn't a bit off-center now? If so, that's all part of a proper alignment.
However, if your car had been in an accident and 'only' damaged the fender, I would begin to doubt the person who told you that.
Dave
Old May 12, 2005 | 04:24 AM
BK1's Avatar
BK1
Hello
Oh, I forgot. There's a good possiblilty that its your ball joints. I had that problem on my other car, replaced the ball joints and the problem went away. Get a second opinion first.
Old May 12, 2005 | 05:01 AM
njmaxseltd's Avatar
Front
Caster
Left 2.5
Right 3.2
camber
Left 0.1
right -0.3
Toe
left 0.1
right 0.1
Total 0.2
Those specs aren't bad, but your almost at the limit with Caster on the right front and also the differance between the left and right Caster readings is close to the limit as well. Your at a .7 diff, spec says no more then .75.
Try to swap left and right front tires and see if it improves or goes away.
Old May 12, 2005 | 08:38 AM
lshi0's Avatar
thanks for all the valuable advices, by the way, how can you tell from alignment report that if tie rod and ball joint are bad? thanks again!
Old May 12, 2005 | 08:54 AM
cardana24's Avatar
Blown
if your tires are directional make sure they are on the correct side. I also had a problem with my car pulling before I put my coilovers on...after I put my coilovers on and had it re aligned (I had already had it alligned about 4 times) the pull was gone...I am guessing a blown strut was to blame.
Old May 12, 2005 | 08:55 AM
lshi0's Avatar
Dave
nah, steering wheel is perfectly at 12clock
Old May 12, 2005 | 09:05 AM
MaximaSE96's Avatar
Maxima Owner
they shouldnt have aligned ur car if u had bad ball-joints ot tie rods
Old May 12, 2005 | 01:38 PM
BK1's Avatar
BK1
Hello
I agree with this.
Old May 12, 2005 | 02:30 PM
ewuzh's Avatar
Originally Posted by DragonMaxima
Related Problem:
Thanks.
Your actual steering wheel is out of alignment. This would happen a lot in my old Acura Legend. You need to remove the steering wheel completely and put it back on so that it is aligned.
Old May 12, 2005 | 02:32 PM
ewuzh's Avatar
Yes, mine has a slight pull to the right also. I got an alignment done and it went away for maybe 50 miles, but it came back again. No idea how to get rid of it. Tire pressures are all good, etc, etc.. I just told myself it would be something I had to live with.
HA they don't care, they just strap it to the machine, have you ever seen them bother to check balljoints/tierods before they start
Old May 12, 2005 | 02:41 PM
Frank Fontaine's Avatar
Front
Caster
Left 2.5
Right 3.2
camber
Left 0.1
right -0.3
Toe
left 0.1
right 0.1
Total 0.2
Rear
Camber
Left -0.1
Right -1.3
Toe
Left 0.1
Right0.05
Total 0.15
Your rear left camber is not within the range--the range is -1.8 to -0.3.
Based on everything that's been said on this thread, I think your power passenger seat motor is the problem.
Just kidding, to all of you out there, there's a diff. between the pull and the drift, just as there's a difference between a squeal and a groan when it comes to brakes.
I didn't believe it either until I drove a lot to Montreal, where the highway has no crown whatsoever. On the NYS side, my car drifted towards the shoulder, be it left or right, depending on which lane I was in. In Canada, right over the border, it went straight for a very long time with no hands on the wheel.
Old May 13, 2005 | 04:22 AM
BK1's Avatar
BK1
Hello
The meineke by my house didn't go thru with the alignment because of the ball joints. They were right about the ball joints, the car drove much better after it was done.
Old May 13, 2005 | 04:32 AM
omp gah
Old May 21, 2005 | 09:21 AM
Yohann's Avatar
Front
Caster
Left 2.5
Right 3.2
camber
Left 0.1
right -0.3
Toe
left 0.1
right 0.1
Total 0.2
Rear
Camber
Left -0.1
Right -1.3
Toe
Left 0.1
Right0.05
Total 0.15
If anything with these specs, the car should pull left. If it you swap the front tires and it pulls left, it's the tire, otherwise it could be tire pressure being low on the right or a dragging brake caliper.
Lakersallday24
Jun 16, 2019 01:35 AM
homewrecker
Aug 24, 2015 08:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
