Ipod Itrip
Old May 11, 2005 | 04:54 PM
proguitar04's Avatar
Ipod Itrip
I just bought an Itrip for my Ipod and tried it out. Theres some static, though it changes depending on where I put it. I was wondering, could I splice into the antenna wire directly behind the reciever, possibly with a wire tap, and just trail some wire out in front of the dash? If I did this, I coulld put my Ipod right next to the antenna wire. If it's possible, what kind of wire should I get?
Old May 11, 2005 | 05:42 PM
OrestP's Avatar
I dont think the FM way is way to go. I just tried the xtrememac airplay (basically the same as the itrip) and got the same results. I tried the cassette adapter back-to-back and its way better.
Old May 11, 2005 | 06:56 PM
Cal0205's Avatar
Someone on the forum hooked one up.
Old May 11, 2005 | 08:43 PM
gatorade's Avatar
I got the the thing that hooks the ipod up through tape deck, works great.
Old May 11, 2005 | 09:57 PM
mingus2112's Avatar
what's a tape deck
Old May 11, 2005 | 11:14 PM
Nismo3112's Avatar
Custom User Title
Old May 12, 2005 | 07:45 AM
FormorAccordMan's Avatar
Originally Posted by Nismo3112
What is that?
Old May 12, 2005 | 10:35 AM
tomservo291's Avatar
using a casette adapter for now.. sounds good
when I have some extra cash I'll be getting a wired FM modulator...
Old May 12, 2005 | 11:01 AM
I don't have a tape deck in my car. Either way, i'm still looking for an answer to my question. And by the by, can you explain what you did nismo?
Old May 12, 2005 | 11:04 AM
Does your wireless FM modulator have something that you can splice into the antenna? I'm confused, I thought the point of that iTrip is that it is wireless. (You definitely cannot, lets say, splice a wire for the headphone output into the Antenna if that's what you meant, but I don't think it is...)
To do this you need a wired FM modulator, which is powered by the car and has an on/off switch; it goes in-line with the antenna. When turned on it broadcasts to a preset frequency, and you just tune the stereo to it (same thing as your iTrip, only it is wired.)
Also, are you using a stock deck? If you have an aftermarket deck, most brands have a adapter you can plug into the CD-Changer jack that provides RCA aux inputs that you can then get a minijack -> dual RCA splitter and connect your iPod or any other AUX input to.
Old May 12, 2005 | 11:19 AM
Xugg's Avatar
itrip is useless, unless your happy with static everywhere you go. Even tape deck adapters will give you noticeable static. I'd go with a 99$ HU with 1/8" AUX input for a clean sound.
Old May 12, 2005 | 11:56 AM
Yea, theres alot of static. What I wasnted to do was splice into the antenna directly behind the deck, and lead that wire out in front of the dash and put the ipod right next to it, so it could be right next to the antenna.
Old Jun 5, 2005 | 04:46 PM
alphaerror's Avatar
did you do yer input on a stock bose stereo? or something else?
Old Jun 5, 2005 | 04:49 PM
Kevlo911's Avatar
Kevlo for President
It all depends what station your on, my friend has the genaric one from radioshack it worked perfectly in my car.
Old Jun 5, 2005 | 05:03 PM
kcryan's Avatar
I had the itrip, then got the monster which was better but not great, now i got an alpine HU and im gonna hard wire it up
Old Jun 5, 2005 | 05:15 PM
mendon99's Avatar
tastey wheat
this topic was covered a hundred times in the audio forum.
http://forums.maxima.org/showthread.php?t=345413
heres one for example
Old Jun 5, 2005 | 06:59 PM
packetscan's Avatar
I'm stuck using an Itrip for now as i don't have time to hardwire it. But it's coming i have orded the harness for my clarion. If you put the volume on the ipod over 75-80 percent then it will start to distort horibly. I usually run mine at 50 % volume and it great. But i also have the car charged plug in all the time, this does increase the power avialable to the itrip therfore extending the range. I just keep it on the seat for easy access.
scutmud
Aug 28, 2015 05:04 AM
Raw_Toast
Jun 19, 2005 08:57 PM
guyincognito
Jul 25, 2004 08:47 PM
adamschwartz
Feb 16, 2004 02:34 PM
